Re: 73 nova timing
Hey mxpx182lit. Listen this stock cam that you have in your car, when was it installed? The reason i ask is i had the same problem that your having, i had a 306 cam put in my 75 nova, after everything was put back together it was popping back though the carb sounding like a firecracker then it would die,there were two things wrong with it. first-the valves and the cam were not in time together,heres how to fix that. take off the drivers side valve cover,bump over the motor do not start it) until both rockerarms are down towards the intake, pull your #1 plug out get a small wire are something put it in where your sparkplug goes and feel for the piston it should be up, if not do it again until you can feel it. then drop in your distributor firing on #1 that problem is fixed. now second-make sure that you are not over tighten the rocker arms & valves. start the car loosen the rockerarms on one side (do one at a time) until they make noise then slowly tighten them until the noise stops. do all of them that way and your nova will come back alive in time for your race.
