Originally Posted by boschmann
Well, I guess it's on to fuel system. How old is the fuel filter? Do you have access to a basic fuel pressure gauge? Fuel pressure problems oftemn do not set codes either.
Well, after checking my records, it seems the fuel filter was last replaced @ 105K. I am now @ 153K miles.
I specifically asked the last time the car was in the shop and they said it was okay. However, he didn't specifically answer my question when I asked about that. I thought maybe it was going bad too.
Probably worth replacing. I don't have a fuel pressure gauge, but could buy one if it's worth the money.
I was also thinking that I could of possible purged the codes by accident. I was reading one of your other posts about how NOT to jump the connection BEFORE you turn on the ignition. However, I feel I did it correctly prior to trying this and got the same results.
It's probably worth driving another week to see if I can generate the codes again if they were there. I'll check into the Fuel Filter.
I've heard that these are easy to replace, however, de-pressurizing the fuel system is advised before disconeccting it. I heard to do this, you remove the fuel pump fuse, and then you start the car to drain any pressure in the line, then you can replace the filter.
Please confirm if that is correct.
Thank you!
Jeff
