Go Back   Automotive Forums .com Car Chat > Jeep > Wrangler
Thread Tools Search this Thread
Old 04-08-2004, 02:18 AM   #1
speedindevil
speedindevil's Avatar
Send a message via AIM to speedindevil Send a message via Yahoo to speedindevil
2" shackle lift Any Relocations needed?
Hey guys and gals, I was wondering if I put a 2" shackle lift on my YJ if I would have to extend the brake lines, drop the pitman arm down and drop the transfer case down or get a CV driveshaft to make it ride right. Any into is appreciated. Also, I was wondering if the newer soft tops or the sailcloth tops are any quieter at highway speeds? Thanks
"If you have tried to do something and failed, you are vastly better off than if you had tried to do nothing and succeded"-----(someone famous)-----
speedindevil is offline   Reply With Quote
Old 04-08-2004, 06:28 PM   #2
windywinters
Re: 2" shackle lift Any Relocations needed?
I would buy a lift kit that includes : transfer case lowering spacers and dropped pitman arm as these are recommended for suspension lifts of 2" or more. Brake lines should be ok. I have a Best Top bikini top & windjammer and it keeps the air from coming thru the back but it's still noisy. All part of the JEEP experience I guess.
windywinters is offline   Reply With Quote
Old 04-18-2004, 10:55 PM   #3
goinbig
Send a message via AIM to goinbig
If the brake lines are a little tight (especially while flexing) you can just move the brackets, that holds the lines to the frame/body, down a little on the frame until there is enough slack.
goinbig is offline   Reply With Quote
Old 04-18-2004, 10:58 PM   #4
goinbig
Also, have you already bought the shackle lift already? That is a lot of lift coming from the shackles. When they are that long, they become very unstable, especially if you plan on going off road. I would consider a suspension lift, add a leafs, or a body lift. You could also do something like a 1" body lift and a 1" shackle lift.
Old 09-23-2004, 07:47 PM   #5
YJ_steve
i have a 2" shackel lift on my YJ and it rides fine without any modifications, although it flattens out the leaf springs a little. I am in the process of doing a "spring-over" lift which is what a would reccomend for the YJ's. That way you can use the stock springs and you get the same ride (not as stiff as a spring lift) and you get 5 inches of lift. Although if you do this big of a lift, you need the following: a skid drop kit, drop pitman arm, brake lines, new spring perches, shocks, rear driveshaft, and a slip yoke eliminator. It will come out to about $800 worth of parts but you'll be ahead of the game compaired to a spring lift.
YJ_steve is offline   Reply With Quote
Bookmarks
Search this Thread:
