| Latest | 0 Rplys |
03-29-2004, 08:17 PM | #1 | |
Help! '96 windstar oil in coolant
My windstar with the 3.8 liter has oil in the radiator coolant. No sign of coolant in the crankcase oil. Help me diagnose this please. Where in this engine are the oil (under pressure) and coolant in close proximity to each other? Thanks. Tom
03-30-2004, 02:47 AM | #2 | |
Re: Help! '96 windstar oil in coolant
Tom,
Hate to say it but, blown head gasket.The 3.8 has a history of this. Sorry. |
03-30-2004, 11:05 AM | #3 | |
Tom, How many miles on the van ???? Just wondering.
jim |
03-30-2004, 11:15 AM | #4 | |
That issue is exactly why we have a '98 WS with the 3.0L, and NOT the POS 3.8L.
I'm sorry to agree with the others, but it sounds like the head gasket is toast. The REALLY bad news is that the repair is typically $1500 and up! |
03-30-2004, 01:33 PM | #5 | |
Re: Re: Help! '96 windstar oil in coolant
Could also be the lower intake manifold gasket, which if it is would be less expensive to replace.
03-30-2004, 01:42 PM | #6 | |
No, he said he has no coolant in the oil. If the intake gasket goes, you get coolant in the oil, NOT oil in the coolant.
03-30-2004, 09:21 PM | #7 | |
The van has 93,000 miles on it. If i'm reading you all correctly, this would be a leak between a coolant passage and an oil passage within the head gasket, right? Do you think that this situation will lead to more internal engine damage? I'm planning on having it repaired, but as long as it is torn down should I look at anything else? I assume that since there is no coolant in the motor oil the bearings etc should be OK.
03-30-2004, 09:28 PM | #8 | |
By the way mcdrunky, what IS a good van these days?
03-31-2004, 12:49 AM | #9 | ||
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
03-31-2004, 01:03 PM | #10 | |
"What is a good van..?"
IMO, a Toyota Cienna, or *maybe* a Freestar. Ford WORRIES ME. They do not look after customer satisfaction well, and many of their dealers are worse (from personal expierences). |
03-31-2004, 01:33 PM | #11 | ||
http://www.blackstone-labs.com/auto_report_3.html |
03-31-2004, 07:51 PM | #12 | |
I had the cooling system pressure tested today and it was not too bad--1.4 lbs lost in a 2 hour period. No external leaks detected. No coolant in the oil. I'm thinking that I'm going to flush the cooling system and put a can of Mendtite in with the new coolant and keep a close eye on it for the next couple of weeks to see what happens. Sound OK?
03-31-2004, 09:41 PM | #13 | ||
G/luck Joel
05-24-2004, 11:22 PM | #14 | ||
I have a 95 3.8 and the head gaskets went so I spent $1400 on the top end and then 7 months later the bottom end went, they are known for have main bearings destroyed by anti-freeze, ended up getting whole rebuilt motor $3200.00 (wish I would of done that in the first place) |
01-18-2005, 12:00 PM | #15 | |
This is happening to my 97 Windstar now. What diagnosis did you come with after all? It will help me to find out what to do.
