Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 03-29-2004, 06:28 PM   #1
browntruck
Post 97 chevy blazer whinning noise from fuel tank area
I have a 97 s series blazer making a loud whinning noise from what seems to be from the fuel tank area. What could this be? The fuel pump going out? I know the pump always makes a slight whinning noise, but this is a whole lot louder that normal.
browntruck is offline   Reply With Quote
Old 03-31-2004, 12:14 AM   #2
www451oa
Re: 97 chevy blazer whinning noise from fuel tank area
Sounds like your fuel pump. No do you get your gas from the cheapest no-name gas station around, or do you buy from a name brand dealer? If the gas you bough had some foreign substance in it, it could cause the pump to have problems.
I had bought super cheap gas from a no name station once, my engine ran horrible and I had some water in my fuel. After that, I went back to my reputable dealer and have had no problems.
Try running a bottle of good fuel system cleaner. Expect to pay around $10.00.
On other thing. Have you backed over any 8 year olds lately? They can get jammed up around your gas tank. If this is your problem, grab the strap on their pokemon backpack, and give 'em a good yank. it should remove them. This will also cause a whining sound from your tank area.
www451oa is offline   Reply With Quote
Old 03-31-2004, 03:20 PM   #3
TopDogg
Does the noise get louder the longer its running? Next time it gets loud keep the truck running and open the gas tank cap. If it calms down your tank isnt venting and the pump has to suck harder.
TopDogg is offline   Reply With Quote
Old 03-31-2004, 10:13 PM   #4
browntruck
how do i get it to vent if that is the problem?
Old 04-01-2004, 09:31 AM   #5
TopDogg
first you should drive it for awhile long enough to ude about a gallon of gas. If it is whinning then open the gas cap and you might here air being sucked INTO the tank. If its the case then air is not replacing used fuel and the pump is actualy pumping in the sides of the tank. My Camaro did this. There will be a valve under the truck near the tank connected to the tank by a hose. CHeck that first.
Old 04-06-2004, 05:27 PM   #6
plant
Its definately your fuel pump mine is the same as is all others. Its no problem
plant is offline   Reply With Quote
2001 Accord Manual --weird hissing / grinding noise from Back seat area! shivparekh Accord/TSX/Accord Hybrid 7 01-10-2010 07:42 AM
98 lesabre noise from fuel tank army LeSabre 2 11-16-2009 01:51 AM
1996 2.2L Noise from fuel tank Mitcheky Cavalier Problem Diagnosis 5 08-25-2008 08:46 PM
Whining noise from gas tank area Airhead315 Accent | Verna 2 03-09-2006 07:19 PM
High pitch noise from fuel tank area gmcswok Century 2 11-27-2004 07:27 PM
