I had a similar problem with my van. On mine, the fan would not turn on once it reached the tempature at which it SHOULD come on. I determined that it was the radiator fan switch by doing these steps:
1. Locate the switch, near the bottom of the radiator fan.
2. disconnect the wiring/power supply from the switch.
3. in the end of the plug that you just removed, there should be
slots, similar to that of the female end of an extention cord.
4. DISCONNECT THE CAR BATTERY, and then take a small section
of a wire coat hanger and bend it into a "U" shape.
5. Carefully insert each end of the "U" into each opening in the
plug. Doing this will actually bypass the switch in the fan.
6. Let the rigged plug dangle freely, and connect the battery
again. Once the battery is connected, simply turn the ignition
into the "on" position, and if the radiator switch is the problem,
the fan should turn on.
By bypassing the radiator switch and causing the fan to turn on, we have determined that the switch is the problem, because once the switch reaches a certian tempature, it completes the circut with the plug and turns the fan on; much like a thermostat. If the thermostat in the switch is stuck or no longer active, it won't complete the circut when the tempature is reached, causing the fan to not come on, causing the van to make a huge scene with all kinds of smoke coming from under the hood. Good luck with the test, and just for the record, the radiator switch is 11.98 at Auto Zone.
