Thread Tools Search this Thread
Old 11-15-2003, 07:09 PM   #1
CamaroSSBoy346
CamaroSSBoy346's Avatar
Send a message via AIM to CamaroSSBoy346
HOW TO: Make Covers for your truck beds
Got an audio/video system in the back of your pickup truck? Or anything else that you want protected for that matter? Or maybe you got a drag racing pickup, and have one for aerodynamics, or just put on on there for the sake of having one. Well, you might want to pay attention
Firstly: Tools; Wire cutters, industrial scissors, automotive primer filler (Dupli Color is my reccomandation), perminant marker, and an old jewel case/c/d case.
Secondly: Everything has to be below or right at the bedline if you want this to work (DUH!). Tre truck im using is my AMT 1993 Ford F-150 First lay the top of the jewel case on top of the bed. Out line the bed with a perminant marker
Thirdly: Use the scissors to cut off the rim, and cut untill your about an inch away from the marker line. The reson for this is while your cutting the plastic it will crack. Next take your wire cutter and cut a milimeter away from the marker line, then half a meter, then so on untill your 3 mm away for the line. Once your at this point, sand it. You'll need a rough enough grit to be able to sand this. Im not sure what grid i used, so you'll have to decide.
Fourthly: This is why i use filler primer. Just incase you do actually scratch or crack it the filler primer fills in the crack's easily. This is also a really great place to do some work with an air brush; do murals etc. I got a couple ideas of my own; stay tuned.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
CamaroSSBoy346 is offline   Reply With Quote
Old 11-15-2003, 07:18 PM   #2
weaponCIVIC
weaponCIVIC's Avatar
Re: HOW TO: Make Covers for your truck beds
this helps me alot i was thinking of ways to do this.
weaponCIVIC is offline   Reply With Quote
Old 11-15-2003, 07:32 PM   #3
Zcaithaca
fershizzle
Zcaithaca's Avatar
Send a message via AIM to Zcaithaca
kool i gotta try this i could us ethe water slides from my 64 impala lowrider kit
Zach
Zcaithaca is offline   Reply With Quote
Old 11-15-2003, 08:39 PM   #4
SonyMobile
SonyMobile's Avatar
Send a message via AIM to SonyMobile Send a message via Yahoo to SonyMobile
Great Idea , but can I make one suggestion, instead of gowing through all the hassle of cutting with this and cutting with that, if you heat up a knife blade you can get the job done alot quicker, you'll still have to sand the edges but it might be a bit quicker than using all the different cutters n stuff, just my thoughts.
SonyMobile is offline   Reply With Quote
Old 11-15-2003, 09:20 PM   #5
EMAXX
EMAXX's Avatar
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Great idea dude. I might have to use this on a few models.
EMAXX is offline   Reply With Quote
Old 11-15-2003, 09:28 PM   #6
86_SR5
86_SR5's Avatar
Re: Re: HOW TO: Make Covers for your truck beds
Mike, I was simply going to use some .030 styrene card, but I like that clear idea. Looks real nice, since I'll be putting some bump, bump in the SS real soon.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
86_SR5 is offline   Reply With Quote
Old 11-15-2003, 10:46 PM   #7
CamaroSSBoy346
Heres some results; my cool (imo) flame job. A mix of yellow, silver, red, dark red, red mixed with clear orange... still need to clear coat it etc.
Old 11-16-2003, 11:29 AM   #8
86_SR5
86_SR5's Avatar
Shoulda done a big FORD emblem or something like that, but hey, that's pretty cool.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 11-17-2003, 07:49 AM   #9
EMAXX
EMAXX's Avatar
What did you use to do the flame? A brush, or somthing else?
Old 11-17-2003, 03:50 PM   #10
CamaroSSBoy346
no, its all hand painted with a standard testors paint brush
Old 11-17-2003, 06:23 PM   #11
86_SR5
86_SR5's Avatar
Usefull/less Information: testors paint brush assortment of 3 at wal-mart along with their xacto knives and bottles of paint are all 97 cents each.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 11-18-2003, 07:55 AM   #12
EMAXX
EMAXX's Avatar
Yeah, I use the Testors paints a lot. They're so cheap, and when I use them through an airbrush, I get such good results.
Old 11-18-2003, 03:09 PM   #13
86_SR5
86_SR5's Avatar
My favorite testors paints so far have been flat red, and regular green for tein suspensions on my latest project.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 11-18-2003, 03:25 PM   #14
CamaroSSBoy346
i use the paint brush that comes in their value pack; the smallest one.
Bookmarks
Search this Thread:
