Re: Replacing headlight bulbs
wow! I don't know, but I think you guys are making it seem a lot harder than it really is!
Pop your hood (disregard the plastic thing on top). There are two metal tabs on each headlight, take a flat-head screwdriver and pry up on them (they only go up and down). Pull forward a bit, remove the side marker bulb, and if you are pulling gently from the headlight the grill will come off with NO PROBLEM, I got both headlamps and the grill to come off with no problem (both headlight housings and the grill acted as one piece), changing all four headlight bulbs took a whole of 2 minutes.
Pull headlights/grill assy out and rest on bumper, pop off plastic covers and replace bulbs. Replace rubber covers, put marker lights back in, pop everything back into place, slide tabs down to lock headlights in, close hood.
I can take pictures if needed.
