Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > TrailBlazer/Trailblazer EXT
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 01-11-2004, 02:51 PM   #16
onphinal
onphinal Normal reputation
Gotta agree with the suggestion to skip removing the grill and go straight to the rubber caps on the back of the headlamp assembly. It takes a little bit more dexterity, but will save you from removing the grill and possibly breaking any fasteners. I figured out that the grill had to come off somehow, but didn't know how to undo the bottom fasteners and didn't want to break them. Then I found this thread and went for the rubber caps leaving the grill installed. I needed to replace the passenger side light and removing the air filter cover was the trick (3 fasteners).
Thanks for the tips.
onphinal is offline
Old 01-18-2004, 01:34 AM   #17
luvchevy
luvchevy Normal reputation
Re: Replacing headlight bulbs
OK, I need to change passenger side headlight bulb 02' Trailblazer. This a true pain, I will go ahead and take off the air filter cover and shimmy myself in there and change that bulb. Please wish me luck. Would hate to go to the dealership for a headlight!
luvchevy is offline
Old 01-18-2004, 06:52 PM   #18
jeremyhelling
jeremyhelling's Avatar
jeremyhelling Normal reputation
This is one of the easiest things you can do on your Trailblazer. If you can't do this, you probably don't possess the motor skills necessary to operate a vehicle.
Jer
www.sylvaniasilverstar.com
1995 Toyota Supra - Quicksilver
2002 Trailblazer SS - Indigo Blue (Show truck/For Sale)
1992 GMC Typhoon - Black/Black #1438 (T3/T4 & methanol injection)
2001 Audi A4 1.8T Quattro - Santorin Blue
jeremyhelling is offline
Old 03-09-2004, 08:28 PM   #19
Icap
Icap Normal reputation
The grill pops off in a few seconds. Use a putty knife to start to pry on the ends of the chrome bar.
Icap is offline
Old 03-11-2004, 07:36 PM   #20
Lucky519
Lucky519 Normal reputation
Send a message via AIM to Lucky519 Send a message via Yahoo to Lucky519
I have replaced the bulbs in both my low and high beams with Street Glow Xenon, and have had numerous problems with the lows, i have replaced them 5 times now, but the highs seem to have no problems. The grill is easily taken off, and the retaining clips on the top of the lights are easily pryed up for access to those black rubber covers. I have found this to be the easiest, as i have had them out numerous times. Do you all have the problems with your tail lights, they have burned out many times on me also. I replaced them with LED aftermarket bulbs, but soon realized they looked very out of place. Is there a way to get the "tinted" tail light lenses found on the SS Trailblazer?
Lucky519 is offline
Old 03-22-2004, 11:49 PM   #21
cateyes355
cateyes355 Normal reputation
I would just like to thank all of you guys (and gals) for the great information you provide me on my TB. Everytime I take it to my dealer for an oil change, I ask about some of the problems I read about on here and they are amazed I know so much (for a lady that is) ha ha. Thanks again, and keep the info coming....
cateyes355 is offline
Old 06-08-2004, 04:44 PM   #22
jimdbnps
jimdbnps Normal reputation
tb headlights
Thanks for the help, It was easy with your directions. Thanks again keep up the good work.
jimdbnps is offline
Old 08-16-2004, 09:09 PM   #23
shoney524
shoney524 Normal reputation
sidemarker lamps
Thanks for all the info on the headlamps...I just bought a used 2002 TB and was looking at what it would take to change the headlamps. It sure looked like it could be a pain. I have not had to do it yet. I do however have a passenger sidemarker lamp that needs to be replaced. I can see it from the top, but I don't know if the connector just unplugs or needs to be turned to the left or right. Thanks for any further info
shoney524 is offline
Old 08-21-2004, 07:43 PM   #24
awallach
awallach Normal reputation
Re: Re: Replacing headlight bulbs
ICAP, you say to use a putty knife to start to pry on the ends of the chrome bar. Are you referring to the middle piece of chrome between the top and bottom part of the grill? How is this fastened to the rest of the grill?
Thank you!
awallach is offline
Old 09-04-2004, 07:26 PM   #25
TB02
TB02 Normal reputation
Changing the bulbs by removing the grill and plastic "radiator cover" is actually very simple. I drove myself crazy until I broke down and bought a Chilton's manual. To change all four bulbs and remove/replace all the necessary plastic only took about 20 minutes... a small price to pay for knowing the correct way to change them. I do a fair bit of maintenance on my 02 TB. I recently heard someone tell me they paid $120 to have their fuel filter changed. The Chilton manual, Fuel filter and 15 minutes only cost me $40. By the way, the Trailblazers are great Trucks! If you don't want to buy a manual, e-mail me and I'll try to help you out by referencing mine.
TB02 is offline
Old 09-06-2004, 10:32 AM   #26
awallach
Replacing Headlight Bulbs the easy Way
OK everyone. Here is the official way to change the headlight bubls right from the mechanics who do it. DO NOT pull the grill off. DO NOT, I REPEAT DO NOT pry the chrome piece off, it's connect with clips except two spots where it's heat shrunck right to the grill. If you try to pry off the chrom piece, then you will eventually break the heat shrunk pieces and then end up replacing the entire grill. Here is what you do as posted before in this forum. For the passenger side, there is an air filter. Take the 3 screws off that holds the cover on and then remove the cover. Now move the hoses out of the way and reach behind the headlights and you will feel two round rubber covers. Pull these off. You should be able to pull them off with your fingers but if you can't use a flathead screwdriver. Now you have easy access to the bubls. Just turn the bulbs to unlock them from the headlights and replace your bubls. Once you have replaced them, reverse the process, put the rubber covers on, put the hoses back in place and put the air filter cover back on and screw it on with the 3 screws. Now the passenger side is done. For the driver side, just reach behind the headlights, pull the rubber covers off, turn the bulbs to unlock them, replace the bulbs and reverse the process. You're all done. Average time to replace all 4 bulbs is 15 minutes and no grill to take off.
Any questions, feel free to email me at awallach@rochester.rr.com
awallach is offline
Old 12-28-2004, 12:48 AM   #27
kuhnman
kuhnman Normal reputation
Lightbulb headlight problems
I have to take mine apart every week. The insert that holds the bulb got hot and melted and had to rewire another one (little piece of GM plastic cost $21.00 that the bulb goes in) and now everytime I crank it the bulb is out, but if I give it a bang the light will come on. May be o.k. for a day and sometimes it will last a week or so then bang it again. As usual it melted right after the warranty went out. I will prob end up hving to buy a complete head light assembly and I'm sure that's about 175.00 not to mention the problem with the fan clutch staying engaged until I reach 50mph and if you don't think that sucks more gas then GM.
kuhnman is offline
Old 12-28-2004, 01:07 PM   #28
Jethro
Jethro
Send a message via AIM to Jethro
Note to self:
Sell Trailblazer the day a headlight goes out.
Jethro is offline
Old 09-03-2005, 10:27 PM   #29
dach95
dach95 Normal reputation
I just bought a pair of silverstars... How are these compared to xenon. xenon seem to be a bit cheaper. does xenon bulb get really hot and melt the light assembly?
2002 Chevy TrailBlazer 4X4 LTZ EXT Summit White
4.2L I6, 3.73 rear diff ratio K&N HighFlow KN-1009 air filter Airaid Throttle Body Spacer Sylvania Silverstar Lows 9006ST
Infinity Burl Wood molded dash kit In-Channel VentShades 35% front windows.
Excellent source of info http://www.trailvoy.com
dach95 is offline
Old 10-25-2006, 06:34 PM   #30
lacanucknb
lacanucknb Normal reputation
I just replaced the passenger side low beam in about 15 mins. Thanks for the easy way!
lacanucknb is offline
Closed Thread
Bookmarks
Google
Web AF
