| Latest | 0 Rplys |
10-02-2003, 07:47 AM | #1 | |
'92 Explorer Heater Core Replacement
Anyone know how to access the heater core?? Do you have to get to it from the engine compartment and by removing the dashboard, or just by removing the dashboard? I have the engine torn apart for a head gasket replacement, and don't want to reassemble the engine and later find out having it partially taken apart will help gain access to the heater core...need to start the project this weekend, so quick responses are appreciated.
10-11-2003, 10:54 AM | #2 | ||
Re: '92 Explorer Heater Core Replacement
Help! |
10-13-2003, 12:41 AM | #3 | |
Replacing heater core in Explorer
There's nothing to it! Pull down the glove box, and locate the 4 screws holding the lower panel covering it, I think they are 5/16" or 7mm , and of course remove the heater hoses fron the engine compartment .It is a good idea too since you are doing all this to replace those old heater
hoses both and use new clamps too.It is not hard at all, just be careful in installing the new heater core and transfer the foam pads from the old core if possible or get some foam padding and glue it to the appropiate areas of the new core.Do also check your coolant as you do not want to put rusty bad coolant in the new core either.This is the easiest thing almost to do on your Explorer,easier than changing plugs If you do not purge all the air out you will run hot, so don't forget to let it idle a while to get all the air out, radiator cap off initially and just let it idle . It may take 3 or 4 startups to fully purge it so recheck your coolant recovery bottle to see if it needs topping up. (This might be the time to do a complete cooling system replacement, all hoses , coolant and thermostat too) |
01-24-2005, 11:12 AM | #4 | |
After reading this, it took all of 8 minutes to have the heater core in my hands. That has to be the best 300 dollars I didn't pay a mechanic!!!!
And Kragen lists the heater core for $16.99. |
