Become a fan of Igor Sushko - Racecar Driver
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Thread Tools Search this Thread
Old 11-16-2001, 10:05 PM   #1
Swonder67
Send a message via AIM to Swonder67
GSR, or type R motor
Aright fellas heres the deal. I'm pretty tired of my little civic gettin revved on and beat by almost every car on the road. (with exception to geo metros)... anyway, I plan on a swap, and I wanna know if you GSR guys are happy with your engines, or should I spring for a type R engine. I plan on going all motor. A GSR motor would be cheaper, but I wanna know if it's worth the money... Help me out guys (and girls, if any).
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Swonder67 is offline   Reply With Quote
Old 11-17-2001, 05:29 AM   #2
Integra-F20C
Integra-F20C's Avatar
Send a message via ICQ to Integra-F20C Send a message via AIM to Integra-F20C
Well..if ya wanna turbo the B18C..then get the GSR B18C1 motor..since it has lower compression so it is better for turbo..but if u want all motor mania...go for B18C4/5 Spec-R engine...which has higher compression which is what u need in a all motor..so it's up to u really..
97 JDM Accord SiR-T
more infoHere
Integra-F20C is offline   Reply With Quote
Old 11-17-2001, 06:54 AM   #3
Swonder67
Well, I'm just worried about the reliability of forcd induction. Thats why I wanna go all motor. And even if I did get a TC or SC, I wouldn't get alot of boost. maybe, 7-10 psi. Nothing like 30 or anything.
35% Platinum tint
Old 11-18-2001, 12:30 AM   #4
F20C
F20C's Avatar
Don't people usually buy LS VTEC engine then Turbo it?
Anyways 30 psi are not suited for Street use. Have fun with lag!!
Old 11-18-2001, 05:21 AM   #5
Integra-F20C
LS vtec is not as reliable!..and most people use it cause it's a damn good all motor engine..it has so much dman more torque then the B18C engine....and so..since it's mostly for a all motor car..
then adding turbo would be stupid..because
high-compression+turbo=boom
and well..if u want all mtoor then go for B18C4/5 Spec-R..since that engine is specially made for all motor 205hp stock if u get a B18C5 Spec-R..which is an higher compression engine.
but if u don't want to boost too much..then just get a B18C1/2/3
and get a T28 ball bearing etc turbo..and run at 0.7bar boost with ur internal settings...that way will be ok boost, enough to scare a few mustangs or 2 and definitely some non turbo cars..goodluck
97 JDM Accord SiR-T
more infoHere
Old 11-18-2001, 05:37 AM   #6
M-type
go with the gsr, cause its the same engine as the type R with different ratios..ect and a little better gas mileage. If you're gonna keep the engine stock, go with the type R. But if you plan on swaping the engine parts later go with the GSR. If you plan on a turbo, get a GSR engine and put sleeves in the cylinders and change the valves and the valve springs before you drop it into your car. If you are getting the turbo for the blow off sound, its not a good idea at 7psi. It not gonna have enough pressure to make those cool noises. Oh here is another idea, you can always but a spoon or a mugen built b18. They are good NA engines. I'm not sure if they are street legal though, but there are always loop holes for those situations. good luck on your car
Powered by Honda. NA tuned at 11.8:1
M-type is offline   Reply With Quote
Old 11-18-2001, 05:12 PM   #7
Swonder67
Technically, and JDM engine in a USDM car is illegal, yeah, I would go NA. I like the GSR motor. hmmm, now, how much money do I have????
35% Platinum tint
Old 11-19-2001, 05:07 PM   #8
Integra-F20C
nah..man...there is heaps between a B18C1/2/3 and a B18C4/5 spec-R..
the ITR engine has bigger throttle body..port and polsihed intake manifold and cylinders..better headers..much better camshafts..higher compressions better pistons..ITR engine is so much mroe better then GSR..and that's why the JDM B18C5 Spec-R engine is liek 205hp..
there is a lot of things that a B18C1/2/3 have to do to make it to 205hp all motor..but of coz...the GSr motor has the bette potential to doing it up...but will cost more..
97 JDM Accord SiR-T
more infoHere
Old 11-19-2001, 06:50 PM   #9
Swonder67
well, if I do get the engine, i'd be redoing it completely. so I'd be gettin new headers, cams, valves, etc. so as long as the block is essentially the same, it'd be ok.
35% Platinum tint
Old 11-20-2001, 02:04 AM   #10
JD@af
Missing in action
JD@af's Avatar
Send a message via ICQ to JD@af Send a message via AIM to JD@af
I know a lot of people very, very happy with the LS/VTEC. I'd recommend this. B18B bottom end, and then any B series VTEC head makes lots of power. I haven't heard any reports of bad reliability from these motors.
As for a JDM engine being illegal in a USDM chassis, well shit, I guess I'm in trouble, because I've got a JDM hybrid. It's never caused me any worries.
Anyway, any of these choices are good. You would probably even be making a big step up in performance even with just a B18B swap.
JD@af is offline   Reply With Quote
Old 11-22-2001, 10:35 PM   #11
Swonder67
Lag won't be too much of a problem with the right blow off valve
35% Platinum tint
Old 07-14-2002, 12:26 PM   #12
PhatAck813
Send a message via AIM to PhatAck813
About the ls/vtec motor
I have an integra LS and I want more power, and I also want to put a turbo on it. For the LS/Vtec conversion, what all is involved. Is it a LS block with gsr head. Please email me back at mab813@hotmail.com or leave a comment explaining. Please help me!!!!
PhatAck813 is offline   Reply With Quote
Old 07-14-2002, 12:34 PM   #13
93speed
93speed's Avatar
I'm sure you could use the search feature to find lots of info.
O/T, but is that Erie as in Erie, PA?
93speed is offline   Reply With Quote
Old 07-16-2002, 10:52 PM   #14
1990 CRVTEC Integ
Send a message via AIM to 1990 CRVTEC Integ
if u gonna go all motor do CRVTEC.....get b20b and a b16a or GSR or if u got the money ITR head. ull have a butt load of torque. plus if u do some fuel tuning and other minor things u could beat a type r.
1990 CRVTEC Integ is offline   Reply With Quote
Old 07-17-2002, 09:52 AM   #15
Marasmus
Send a message via Yahoo to Marasmus
I deliberated the same questions greatly before deciding to buy my GS-R. I went with the GS-R because (1) it's cheaper, (2) parts are a little easier to get than B18C5 parts (if i break something!), and (3) there's a bigger gain to be made when replacing the internals.
if you're doing the whole valve train, pistons, etc... see if you can get a crankshaft from a late B18C5. it's balanced differently (read: better) and will help greatly in your search for the 5-digit RPM's
In case you haven't seen it yet, check out www.hondata.com - they built an all-motor GS-R doing something silly like 258hp. There's a ton of potential with the B18C1 + buildup.
Only real pain in the butt about the GS-R is that you'll need to replace the throttle body with a much bigger one and port-match both the intake and exhaust to a larger diameter, to accomodate adequate airflow at higher RPMs. The Type-R's TB could probably go to 9000rpms without being touched.. just a thought.
Marasmus is offline   Reply With Quote
thread Thread Starter Forum Replies Last Post
How hard is it to make 13 second GSR/Type-R? Twizted_3KGT Integra 17 01-09-2005 09:00 PM
Ls,gsr,type R dmfnded Integra 5 10-30-2004 10:26 PM
Looking for JDM Swaps B16, H22a, GSR, Type-R quality_jdm_motors Canada 0 06-04-2004 10:55 AM
JDM type-r LSD for sale or need gsr/type-r final drive gear set TEAM KLR JDM Motor & Parts info/chat 2 02-14-2004 10:34 PM
altima vs rsx-s or integra gsr, type r itsmeek Street Racing 2 09-15-2002 11:19 AM
Bookmarks
Search this Thread:
Automotive Forums .com - Car Forums - Privacy Statement - Top
Powered by Searchlight © 2013 Axivo Inc.
