Go Back   Automotive Forums .com Car Chat > Cars in General
Thread Tools Search this Thread
Old 01-29-2019, 11:20 PM   #1
beepbeepph
8 Common Car Repair Mistakes You Should Be Avoiding
If you’re a car owner, then you probably already know that having a car can be quite a commitment. After all, you can’t just let it hit the road all the time or let it linger in your garage. If you want it to run smoothly and efficiently, then car maintenance and repair are your safest bet, which means that you need to visit an auto shop or a car shop routinely. Avoid these car repair mistakes that will put your car at risk.
As much as you want the best for your vehicle, there are still instances when certain car maintenance procedures can go awry, or when you forgo certain repairs — all of these, needless, to say, can be damaging to your car and your safety.
In order to avoid these dangerous and costly blunders, it’s advisable that you familiarize yourself with them as early as plausible. Listed below are some of the most common car repair mistakes.
What are the common car repair mistakes?
Opting for a very low-cost mechanic.
Sure, you want to save some money on repairs, and your instinct might be to go to an extremely economical auto shop or car shop. Unfortunately, there’s a reason why there are low-cost mechanics and more expensive ones — that is, the disparity in quality. You don’t want to sacrifice the welfare of your car by opting for cheap services (not to mention that doing so might lead to more repairs in the future).
This doesn’t mean that you need to select the priciest of the bunch. It’s safe if you veer in the mid-range. Additionally, do your homework and check some online reviews or ask for referrals.
Filling the engine with an incorrect type of oil.
Albeit using an incorrect type of oil won’t necessarily lead to engine failure, doing so can still harm your engine and sacrifice its performance. At any rate, it’s best to be sure what sort of oil you’re supposed to put in your engine.
Skipping the oil change.
In other instances, you might decide to skip the oil change altogether. As with the previous one, this might cause your engine to eventually wear out and run less efficiently. In the end, your engine might finally break down.
Not changing dirty filters.
Not changing dirty filters can lead to serious problems in the future. For one, some of your car’s sensors might fail, which means thousands of pesos of repair.
Ignoring scheduled maintenance.
A vehicle’s scheduled visit to an auto shop or car shop is already listed down in the car manual, and yet, some car owners still choose to blatantly ignore it. You shouldn’t! After all, a car manual has all the information you need to know about your car, and this knowledge might spare you from expensive repairs!
Additionally, following all the instructions written in it guarantees that your vehicle will always be functioning seamlessly.
Overlooking your tattered brake pads.
Not changing your brake pads when there’s already a sign of wear and tear can be hazardous to your safety. As you might have guessed, it can lead to some accidents that you easily could have avoided if you replaced your brake pads with new ones.
Some of the most common manifestations of frayed brake pads are difficult when you’re turning a corner and a deafening, screeching sound that accompanies your car every time it comes to halt.
Forgetting to check cars.
For tires, you’ll need to constantly rotate them and to check air pressure. This will help you avoid the imbalanced tread wear on your tires. Uneven tread wear can lead to myriads of issues, such as vibration when driving, irregular traction, and damage to steering and suspension parts.
Most auto shops or car shops will rotate your vehicle for a fee. However, if you have a jack and jack stand, then you can perform it by yourself at the comforts of your home! As for air pressure, you can just have it checked at a nearby gas station.
Lastly, air temperature also disturbs tire inflation. So even if your tires don’t have air seeping out of it, you might still need to have your tires checked, just to be sure.
Neglecting fluids.
These fluids are there for a reason — that is, they ensure that your vehicle will be running smoothly and efficiently. If you want to be sure about the fluids that your car will need, then your car manual is your best friend.
Key Takeaway
Being a car owner isn’t simple. There are tons of things that you need to know and need to do, and one of them is the necessity of regularly visiting an auto shop or a car shop. After all, you need to ensure that your vehicle is always in its prime condition.
Unfortunately, there are times when these repairs aren’t really helping. On the contrary, they can be detrimental to your car. There are also instances when you might deliberately ignore certainly. In order to avoid these car repair mistakes, it’s wise that you familiarize yourself with them.
beepbeepph is offline   Reply With Quote
Bookmarks
Search this Thread:
