Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 02-03-2017, 02:32 PM   #1
dezso3
Question Loose steering
You make a right turn, and you notice that the steering wheel feels very loose, and it takes a long time for it to return to the center. Which components, besides the tie rods, could be loose?
dezso3 is offline   Reply With Quote
Old 02-03-2017, 03:54 PM   #2
maxwedge
A990 racer
Re: Loose steering
And whst vehicle is this??
maxwedge is online now   Reply With Quote
Old 02-03-2017, 04:33 PM   #3
dezso3
Re: Loose steering
It's a 2016 Honda Civic LX sedan.
Old 02-03-2017, 06:39 PM   #4
maxwedge
A990 racer
Re: Loose steering
Should be under warranty? But anything in the steering can cause this.
Old 02-04-2017, 10:23 AM   #5
shorod
SHO No Mo
shorod's Avatar
Re: Loose steering
Is it electric power steering?
-Rod
shorod is offline   Reply With Quote
Old 02-05-2017, 04:24 PM   #6
dezso3
Re: Loose steering
-Rod
Yes, it's dual pinion electric power steering.
Old 02-05-2017, 07:47 PM   #7
shorod
SHO No Mo
shorod's Avatar
Re: Loose steering
Maybe the issue is with the electric assist over-boosting. Have you checked, or had someone check, for looseness in the steering and suspension yet? Have you made sure all lugnuts are properly torqued?
-Rod
Old 03-28-2017, 07:38 AM   #8
RidingOnRailz
RidingOnRailz's Avatar
Cool Re: Loose steering
-Rod
Electric power steering is a great idea, but its execution so far has been on the overboosted side. It's quiet, seemless, and direct. Engineers just need to realize that to provide the same assist level with EPS as with hydraulic, they need to tone it down a bit. Or leave it overboosted for parking, and progressively less over 20mph. Hydraulic adds a degree of latency between steering wheel and the road, with fluid, belts, and a pump.
Hyundai attenpted to recreate that 'slop' with its foray into EPS in 2011 in Sport mode, and ended up with Sonatas and Elantras that steered themselves! What a disaster! Because electric is so direct, it needs less power than an equivalent conventional steering system to provide the same level of assist.
Check your tire pressures: Steering feels more responsive with higher tire pressures, and wheels may not center as quickly with smaller resulting contact patch. I like a little steering heft myself, so on my car I strictly follow the mfg placard on the door B-pillar, or even a little below.
RidingOnRailz is online now   Reply With Quote
Old 03-28-2017, 07:49 AM   #9
RidingOnRailz
Originally Posted by Bondy View Post
Use Power Steering **below 20mph** & Enjoy The Life
Thanks
Bondy
See amendment ^^
Old 04-06-2017, 04:05 PM   #10
military
Re: Loose steering
Dezso, I strongly urge you to use your warranty for this repair. If you attempt to repair it yourself or take it to a non-dealership, you may void your warranty for anything to do with the steering and be struggling with this all on your own.
If you have a problem with the dealership you bought it from, follow the protocols that came with your owner's manual for moving the problem up the ladder. You may also want to be sure everything is documented on the shop order and keep your copies on file for future reference.
military is offline   Reply With Quote
