Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Thread Tools Search this Thread
Old 02-09-2016, 11:50 AM   #1
sassee
sassee's Avatar
Xterra Transmission ???
My daughter has a 2000 Xterra, V-6 4x4. When you first shift from park (or reverse) to drive, there seems to be a longer than normal time before it starts moving. Fluid level good, not burnt however I do not know when it was last changed. I bought it 2 years ago. After it is moving it is fine, no slipping, no noises, NORMAL SHIFTING. could this just be a filter/fluid issue?
Ernie
2000 Nissan Xterra XS
1989 Isuzu Trooper with a mod or 2
1998 Isuzu Trooper 3.5 with a 5-speed with a mod or 2
1985 Chevy K-10 with a mod or 2
sassee is offline   Reply With Quote
Old 02-09-2016, 12:30 PM   #2
MikeCStig
Re: Xterra Transmission ???
It could be the fluid and filter. Transmission fluid does break down over time and thins out, so if it's been that long since the fluid was changed, it may be time for some fresh fluid and a new filter.
Another possibility would be a slight blockage in the valve body. Not necessarily a full on clog, just a little gunk that may restrict the flow of fluid and cause the delayed shift.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than 10,000.
MikeCStig is offline   Reply With Quote
Old 02-09-2016, 12:42 PM   #3
sassee
sassee's Avatar
Like I said, I have no idea when the last (if ever) transmission service was done. I bought the car from the original owner but that really doesn't mean anything these days, she seemed like a space cadet anyway. Fluid didn't look bad/smell bad but no idea about filter. After it picks up drive it is fine the rest of the day until it sits for a while and you start over.
Bookmarks
Search this Thread:
