Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Thread Tools Search this Thread
Old 04-11-2015, 06:50 PM   #1
Angrymechanic
97 pathfinder torque converter bolts
There are no torque converter bolts on my 97 pathfinder to remove. I looked very well behind the flex plate and there are no bolts to be removed, I pulled very hard and wiggled it all around and I can't remove the transmission. what do I do?
Angrymechanic is offline   Reply With Quote
Old 04-11-2015, 08:09 PM   #2
MikeCStig
Re: 97 pathfinder torque converter bolts
There are definitely bolts there, you have to turn the crankshaft to get to them. There are at least 4 of them and they should be removed in a cross pattern.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than 10,000.
MikeCStig is offline   Reply With Quote
Bookmarks
Search this Thread:
