| Latest | 0 Rplys |
01-26-2012, 08:38 PM | #1 | |
Burning Smell
I have a 2000 silverado 1500 4X4, with 290000km on it. I also have a 7.5 foot meyer snow plow attached to the front and about 1320 lbs in the back.
I have a burning smell comming from the front end. It smells like rubber burning, I have been all over that truck and can't figure out where it is coming from. Yes the truck sits perfectly level, and I have turned up the torchen bars 3 and 1/2 turns on each side. If anyone has any ideas, it would be great to hear them. Thanks Brian
My Vehicles: 1989 Chev 3500 4X4 6.2l Deisel 1994 GMC Suburban 4X4 5.7l 1998 Buick Regal 3.8l 2000 Silverado 4X4 5.3l |
01-26-2012, 10:03 PM | #2 | |
Re: Burning Smell
No oil leaks on or around the exhaust manifolds or on the exhaust pipe?
01-27-2012, 07:30 AM | #3 | ||
Re: Burning Smell
01-27-2012, 11:04 AM | #4 | |
Re: Burning Smell
Thank you for the replies....
There are no oil and/or fluid leaks, and the belts seem to be fine. This smell only occurs when I have the snowplow hooked up to the truck. If the plow is off the truck it is fine. I know the plow weight is 750 to 800 pounds, I have about 1300 pounds in the back, the truck sits level. I was just wondering if the plow is to heavy for the truck, but after checking with Meyer, that is the correct set up for that truck. Still stumpped. Thanks
01-27-2012, 11:32 AM | #5 | ||
Re: Burning Smell
new belt and if necessary pulley tensioner. any cracks with your plow issue is a bad belt. oem 105/130 amp alternator or did you change to higher amps one then the belt may be the wrong size. |
01-27-2012, 06:09 PM | #6 | |
One Hot Shot
Re: Burning Smell
Yeah see if you have the smell if you dont hook up the electric for the plow. could be a shorting wire as well burning the rubber sheath around a wire.
01-27-2012, 07:53 PM | #7 | ||
Re: Burning Smell
I only have the burning smell when I am driving the truck with the plow attached to the truck, not when I am actually plowing with the truck. I did however try disconnecting all the power to the plow and then went for a drive, and when I pulled into the shop, I could smell the burning rubber. I waited a few hours hooked up the power for the plow and went for a drive, when I pulled into the shop, I could smell the burning rubber. I took the plow off the truck completely (including all electrical- pump, lights etc.) went for a drive to pick up 1300 pounds of salt, pulled into the shop. NO SMELL. I was thinking, that something might be binding with the weight of the plow, I checked the tires to see if they were rubbing anywhere but there fine, so stumpped again Thanks
01-28-2012, 07:46 AM | #8 | |
Re: Burning Smell
check the cv boots for issues. the correct height for vehicle is when these cv axles are straight with each other . could be if at a good sized angle rubbing. possible the hub bearing is shot and is heating up with the larger load. these hub bearings are a common problem.
