| Latest | 0 Rplys |
01-20-2012, 10:35 AM | #1 | |
Power steering pump, Lower manifol gasket, Missing
Hi
I have Windstar 2000. 1. I noticed a lot of red oil under the right side front wheel, low oil level in Power steering reservoir. There was a leak at the junction of high pressure line and pump, replaced the hose and leak stopped, but recurred after 2 weeks. Now leak is through the small hole behind the front left stud of the power steering pump (power steering pump vent). Anybody knows the solution. Will I have to replace the pump or is any repair kit available and if repaired is it suitable? 2. I loose about a quart of engine oil after every 600 miles there is no smoke but I see oil soiled just below the both sides of the lower intake manifold and trickling down. there is no loss of coolant. Will changing the lower manifold gasket reduce the oil losses. What are the signs of the leaking lower manifold gasket? 3. I replaced motorcraft spark plugs, Throttle position sensor, IAC, fuel pump, PCM relay and Fuel pump relay but still I have some missing during acceleration, if RPM are kept 2000 no missing above and below 2000 RPM. Also after about 150-200 miles engine stalls. I stop, off the ignition and then restart with no problem. But, the cycle repeats after 5- 10 miles. If I stop for an hour it runs again for 100- 150 miles. In city no problem even continuous driving for 6 hours. There are no CEL and impending codes. Fuel pressure at idling is 29 PSI and 35 PSI if pressure regulator hose is disconnected. See link: http://www.automotiveforums.com/vbul....php?t=1067905 Anybody kind enough! Jawaid Last edited by azharj; 03-15-2012 at 10:09 AM. |
01-21-2012, 06:39 AM | #2 | |
Re: Power steering pump, Lower manifol gasket, Missing
I would replace the power steering pump.
The fluid to use is ATF....Mobil 1 ATF is a good choice. It is possible that the oil leak is from the valve cover gaskets. Also verify that the PCV valve and hose are in good working order. After all these years of exposure, it is not uncommon for the PCV hose to get soft and clollapse or crack. For the missing, I would replace the Coil pack. They are high failure on the newer Windstars. The coil pack is a block that contains 3 coils. It is also possible that the fuel pump is becoming intermittent (suggested by the shut down and restart to solve). The fuel pump relay inside the relay box in the engine compartment is a common fail item, and is cheaper & easier than the fuel pump, so I would try that first.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
01-21-2012, 10:26 AM | #3 | |
Thank you Wiswind for answering. I am sorry to mention that PCV hose is new one. I have already replaced the Fuel pump Relay. But is this pressure OK. Cover gasket are almost dry. Please can u kindly tell where is PCV Valve. The Dealer gives me the vale as small pieces of T shaped or L shaped metallic or plastic pipes. I do not how to assemble it
AzharJwaid |
01-21-2012, 06:11 PM | #4 | |
You've been given good advise from wiswind but I would like to add the possibility of bad isolator bolts causing the seepage under the intake manifold.
Have the isolator bolts been replaced with new green ones? Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
01-22-2012, 03:14 PM | #5 | |
Thanks Oscar, here Wiswind is very kind and thanks for your advice, I had it done once. These bolts were like silver with silver washers. And these were tight enough. but I am afraid can it be loose rings, pistons Or valve sleeves. Or may be intake seals parts no 9A425 and 9A424.
Azhar Jawaid |
01-22-2012, 06:10 PM | #6 | |
You're welcome Azhar!
I just realized it's you; I'm glad you are still around. Did you ever fix the problem with the air coming out from the defrost openings?. I'm not sure if the 9A424/5 gaskets will fix your problem. From that picture it seems you have the 3.0 engine. Is that correct?. The isolator bolts I talked about are a common problem ONLY with the 3.8 engine and you can see a picture of them here: CLICK HERE If you have the 3.8 engine and those bolts have not been replaced, it would be a good idea to do so. I had some oil leaking between the (plastic) upper manifold and the (aluminum) lower manifold just above the valve covers and never had a check engine light on (no p0171 or p0174 codes). In case you need to replace such bolts, you can see the entire procedure with picures here: CLICK HERE As far as I know, worn piston rings, pistons or valve components would cause BLUE SMOKE coming out from the exhaust pipe because of oil being burned. You mention there is no smoke, so I wouldn't worry about problems in the cylinders. Oscar. THANKS TO THE ORIGINAL OWNERS OF THE PICTURES AND LINKS.
01-23-2012, 03:55 PM | #7 | |
Dear Olopezm! extremely nice feelings on your comments. You have ammazing memory. Actually I fixed the AC vent issue about six months back. The pictures posted by you were extremely helpful.
I made some modification also. You were right that basic cause was vacuum loss. The only problem was to detect and locate the leak. I was busy so I could not share. But in some post I will share with my all friends. I have some drawings to explain but I will post them this site. My Windstar is 3.8l Year 2000. This is my first experience of American car though very strong, safe and comfortable, yet highly unreliable and undependable. Rubber seals gaskets electrical and plastic parts neither reliable nor durable. Previously I had Toyota or Charade; both Japanese. I had fuel injector cleaned about 6 month back and EGR ports were cleaned and the workshop man applied O2 sensor safe silicon between the plastic and aluminum manifolds according to him bolts and seals were OK. I mentioned that it my car stalls after 200 Miles. Only once the 0171,0174 code came when my car stopped. The workman told me to clean injectors codes disappeared but engine stalling remained there. During this weekend I will replace fuel pump assembly again to see if engine stalling is still there or not. Again thank you for the concern Azhar Jawaid |
01-23-2012, 08:39 PM | #8 | |||||
Hello Azhar,
If the readings are higher than +10 that would surely indicate a vacuum leak, a dead injector or a weak fuel pump and the computer is trying to compensate by adding more fuel to the mixture. Also make sure to use a Fuel Gauge Pressure Tester to rule out a bad fuel pump, nobody wants to end up replacing a properly working component, specially a fuel pump knowing how tedious is to replace one. Fuel pressure spec: key on engine off (KOEO): 35-45psi key on engine running (KOER) at idle: 28-35 psi engine off after 5 minutes: 30-40psi If the readings are lower than -10 it indicates you have an excess of fuel entering the cylinders and the computer is taking fuel from the mixture. That could indicate a leaking injector, a bad Fuel Pressure Regulator (FPR). I hope this helps. Oscar.
01-24-2012, 08:21 PM | #9 | |
On 1999 and newer 3.8L Windstars, the PCV valve is in the front valve cover.
I had a 1996 Windstar, which had the PCV valve in the rear valve cover...so my pictures will be of no help regarding the PCV valve. The fuel pump issue that I have read about is a intermittent failure.......it is fine and then suddenly it stops. This makes diagnosis difficult since everything will be perfect until the failure happens. Also, there is no measurement of the fuel flow or pressure on the Windstar, so the computer, aka PCM, will not give you a code that tells you that there is no fuel flow or pressure, since the computer is not directly monitoring those values.
03-16-2012, 09:59 AM | #10 | |
Dear Friends,
I have changed the fuel pump and filter about 2 months back. I drove 2400 KM with the environmental temperature being 10-25˚C, thanks without stalling, however, while accelerating there were episodes of 5 to 10 second duration of jerking with slow change in RPM and no acceleration. It improved spontaneously. Sometime, during constant speed also, there was sudden jerking and reduction of speed by 10 to 20 KM, and then after a few seconds spontaneously regained the speed. However, there is no check engine light. It seems as if there was no timing advance during acceleration, if we compare to olden times’ system of ignition with distributer. You know I already, have changed TPS, IAC, and Plugs cleaned injectors. In many net posts, the defective CKS (crank shaft position), synchronizer fuel and pump cause the same symptoms. You have suggested, to change the coil pack. Given all this, now from where should I start, CKS, synchronizer or coil pack? 2. A strange phenomenon occurred concerning engine oil consumption. The only thing I remember, is that I used motorcraft injector cleaner for 400 KM. Now there is no loss of oil. 3. I also changed the steering oil pump and the high-pressure hose as these were leaking too much; tensioner and idler pulley as these were noisy. |
03-16-2012, 03:57 PM | #11 | |
I would get a new coil pack instead of the new sensor. As far as I know a failing sensor would make the engine to stop running rather than misfiring or hesitating.
Remove it and TAKE A LOOK at the back of it, where the epoxy is. This is where the body starts to crack and causes the spark to arc to ground, causing the missing. Oscar.
06-11-2012, 03:38 PM | #12 | |
Dear All Members,
Thanks for all suggetions. Just to refresh, till now I have changed IAC, TPS, PCV spark plugs (Original ford) wires, Steerirng pump, original fuel pump, lower intake manifold gaskets; during this re-done of 0171 0174. The trasmission rechecked no defect, ATF (Mercon V) level and quality OK. Gear change and ratio normal, no code, checked with code reader, no code no pending code defect no CEL. Checked EGR VALVE as yiur advice. Cleaned the TRS harness VSS Pressed OD while jerking, it continued. Jerks have become frequent (during last 2 years), and now appear most of the time while reaccelerating the RPM reach are 1000 to 1500 and speed is 40 miles/h, or 50 to 60 miles/ h. Some time during jerks the RPM needle stuck at 1000 or 1500 despite the increase gas then suddenly RPM increase and jerk disappear, only to appear againe while reaccalerating RPM are 1000 to 1500. some time at constnt speed of 120 sudden Jerks and fall in speed and RPM. Now planning to change synchronizer, cpk, coil pack one by one in the order of inexpensiveness. Any suggestion. |
06-11-2012, 07:12 PM | #13 | |
You haven't mentioned the underbody fuel filter. Has it been replaced recently?
06-11-2012, 09:31 PM | #14 | |
Hi Azharj,
I'm thinking the jerking could be related to a bad Torque Converter Clutch solenoid (TCC) but you mention that the transmission has been diagnosed and showed no problems. Also, you say that the OD button didn't help while jerking. That leaves with an air-fuel mixture or ignition problem causing the engine to not provide enough torque to the transmission. I don't think the synchronizer or ckp could cause the problems so I would go ahead with replacing the coil pack. I think I remember you said to have checked for vacuum leaks and there were none, right? Oscar.
06-25-2012, 03:59 PM | #15 | |
Dear Olopezm
Thanks I have made up my mind to replace coil pack. But my mechanic disconnected all O2 sensors, there is some change. Most of the time there are no jerk, though not fully curing. Any explanation? or Will it harm? I am now convinced that the problem is of ignition. A new change which I am observing is that it started in first click but now I have to crank twice. In a few days I will change coil pack and let u know. thanks AzharJ |
