| Latest | 0 Rplys |
12-13-2011, 09:27 PM | #1 | |
98 Ram Brake Problems
I have a 98 Ram 1500 and when i hit the brakes the pedal goes all the way to the floor. It stops but not safely. I checked the reservoir and it was kinda full. Should I fill it to the top? There are no leaks around the truck either i saw in another post that it could be leaking into the wheel cylinders? I really need some help asap the truck is in danger of getting towed from where im at. Any advise would be greatly appreciated!!! Thanks.
12-14-2011, 06:09 PM | #2 | |
AF - Advisor
Re: 98 Ram Brake Problems
Has there been any brake work done recently?
If not the master cylinder needs to be replaced imo. The piston inside is worn out.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
12-14-2011, 09:12 PM | #3 | |
i dont think so what youre sayin is probly right that was my next gess. its actually not my truck its my girlfriends. thanks for the advice
