| Latest | 0 Rplys |
10-13-2011, 05:57 AM | #1 | |
1999 Jimmy Brakes go to the floor
I have a 1999 Jimmy that i bought a few weeks back. The brakes go all the way to the floor to stop and even then they are not full brakes. I changed the pads and the master cylinder. I am having the same issue. I did have the brakes bled by a friend but this did no good. They were bled the old school way not sure if you have to bleed a different way but any help. Thanks
10-13-2011, 12:12 PM | #2 | |
A990 racer
Re: 1999 Jimmy Brakes go to the floor
Are the rear brakes ok and adjusted properly( drums I assume). Also if the system was run out of brake fluid at one time the abs must be bled, that requires a high line scanner.
10-13-2011, 01:44 PM | #3 | |
The rear brakes are disc, but when i first tried to bleed them the rear brakes didn't even work , there was alot of air in the system but from normal bleeding there is straight fluid coming out and there are no leaks. What is a high line scanner and can i do it myself or should i take it to a shop. Also the rear brakes are working now but the pedal goes all the way to the floor. When the truck is turned off though it will build pressure.
10-13-2011, 03:19 PM | #4 | |
One Hot Shot
did you bench bleed the master cyl before you put it in
http://autorepair.about.com/od/fixit...ench-bleed.htm |
10-13-2011, 06:37 PM | #5 | ||
A990 racer
Thread Tools | |
