Become a fan of Igor Sushko - Racecar Driver
Go Back   Automotive Forums .com Car Chat > GMC > Sonoma | S-15
Thread Tools Search this Thread
Old 09-30-2011, 07:19 PM   #1
rprough
rprough's Avatar
Rear Differential Information
Going to replace my open style rear end with a locking style rear end. Probably get a Richmond Gear product. what I want to know is how do I find out how many splines are on my axle and what is the ring gear size. Is it 7.500 or a 7.625? I know it is a 3.42 ratio.
I have a 93 sonoma 4 wheel drive. 4.3Z engine. Ext. cab.
Thanks
God Bless America
rprough is offline   Reply With Quote
Old 09-30-2011, 09:45 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
Re: Rear Differential Information
Check the RPO, (Regular Production Options) code sticker. White sticker with black letters, about 2" x 3". Possibly in the glove box, or a door jamb. There are several columns of 3 character codes, post the ones that start with "G" and we can tell you exactly what you're looking for.
Due to the rising cost of ammunition,
warning shots will no longer be issued.
old_master is offline   Reply With Quote
Old 09-30-2011, 10:19 PM   #3
rprough
rprough's Avatar
Only G codes are GMC and the gu6 (3.42 ratio).GMC code is made in Pontiac Michiga. Thats it. I got five lines of rpo's if ya want to know more.
God Bless America
Old 09-30-2011, 10:27 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
The GU6 only tells the axle ratio, which you already know. The only way to know how many splines are on the axle shaft is to pull it out. Once you have it out, (you've already got the cover off) measure the ring gear
Old 09-30-2011, 10:33 PM   #5
rprough
rprough's Avatar
I was gonna change the gear oil anyhow so I reckon Ill be counting some splines and teeth.
God Bless America
thread Thread Starter Forum Replies Last Post
AWD Rear End NOISE BigBriar63 Rendezvous 1 05-10-2010 10:59 PM
How hard is a rear differential pinion seal to replace? mkenyon2 Modifications/How To 3 03-16-2010 10:58 AM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 09:10 AM
95 yukon winding noise in rear dadof2gurls Yukon 2 08-31-2009 06:49 PM
90 rear differential--compatable rear ends? javatrooper Trooper | SLX | Bighorn | Wizard 0 02-01-2007 11:05 AM
Bookmarks
Search this Thread:
Automotive Forums .com - Car Forums - Privacy Statement - Top
Powered by Searchlight © 2013 Axivo Inc.
