Go Back   Automotive Forums .com Car Chat > Cadillac > Seville
Old 09-28-2011, 04:09 PM   #1
ellis479
Cool 2001 cadillac sls pulses when a/c is on
Hello,
My 2001 cadillac sls will pulse up and down @ idle when the a/c is on. It does this constantly, not like when the a/c is engaging and dissengaging. It runs smooth when a/c is off. Thanks ellis479
ellis479 is offline   Reply With Quote
Old 09-28-2011, 07:55 PM   #2
maxwedge
A990 racer
Re: 2001 cadillac sls pulses when a/c is on
The pcm is try to stabilize the idle, now as the compressor cycles the idle will vary slightly, if it is a gross change in speed, the throttle bodyand/or isc could be dirty or faulty ( the iac), a full scan may show something or an experienced tech can find out what's what.
maxwedge is offline   Reply With Quote
The Following User Says Thank You to maxwedge For This Useful Post:
ellis479 (09-30-2011)
Old 09-30-2011, 02:13 PM   #3
ellis479
Cool Re: 2001 cadillac sls pulses when a/c is on
Maxwedge,
Thanks for the information. I couldn't figure out why it only fluctuates when the a/c was running. Once again it's not like the clutch cycling, much more rapid. Thank you ellis479
Old 01-10-2012, 02:27 PM   #4
ellis479
Maxwedge,
I had the throttle body cleaned and the camshaft sensor replaced. This not only fixed the idle problem, but increased the gas milage dramatically. Thanks for your help...........Ellis479
Old 01-10-2012, 04:07 PM   #5
maxwedge
A990 racer
Thanks for posting back results, did a scan show a cam sensor issue?
Replacing front wheel bearing cadillac SLS ellis479 Seville 1 09-15-2011 04:31 PM
2001 Cadillac SLS SURGE @ IDLE ellis479 Seville 0 09-15-2011 04:29 PM
2001 Cadillac SLS PCV Location ellis479 Seville 1 09-05-2011 04:27 PM
Where is information on the Cadillac SLS model? MrBruce General Discussion 9 02-24-2011 09:19 AM
GMC 2001 Jimmy SLS for Sale Keemosavy Cars/Parts for Sale/Exchange 1 03-01-2006 12:29 AM
