| Latest | 0 Rplys |
08-11-2011, 11:17 PM | #1 | |
2002 ram2500 ac drain
My A/c drain has been plugging up pretty regular since changing out the heater core last winter. Figured they left trash in the pan. It is plugged again but I can't get it open-even tried a shop vac with a smalll hose on the drain hole. Is there a way to blow the drain out from the other end? I guess it could be stopped up at the pan where the heater core and the ?condensor sit. Thanks for anyones help.
08-14-2011, 08:45 PM | #2 | |
AF - Advisor
Re: 2002 ram2500 ac drain
You might try shooting air into the drain to try to loosen junk then vacuum it.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
08-16-2011, 03:26 PM | #3 | |
I suggest using the vacuum first. Compressed air will just push all the junk inside further then it already is.
98 Ram 1500 4x4 Flowmaster American Thunder W/super40 |
