| Latest | 0 Rplys |
07-31-2011, 02:11 PM | #1 | |
98 Accord rear brakes not working
I have a 98 Accord with rear disc brakes and ABS. The rotors on the rear brakes are rusted like the pads are not grabbing at all and when you push on the brakes you have to push really hard to get it to stop. I did tests for the booster to see if it is working and it seems to be. Right now I'm thinking it may be the proportioning valve. Any ideas would be appreciated.
07-31-2011, 03:59 PM | #2 | ||
Re: 98 Accord rear brakes not working
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
07-31-2011, 08:09 PM | #3 | |
Lactose the Intolerant
Yeah usually the calipers are seized or the sliding hardware is cheezed up so much it can't move and apply both pads...generally speaking slider problems the inside pad will work but the rotor will be rusty on the outer side since it's not applying that pad, along with extreme pedal effort...seized caliper usually both sides of rotor rusty and often times dragging/scraping sounds from that wheel when turning low speed..
Crack a bleeder screw on each of the rears while someone applies the brakes...if you get a nice strong shot of fluid, the proportioning valve is not your problem.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
08-02-2011, 11:34 AM | #4 | |
I've checked the driver's side wheel by jacking the car up, applying the brakes with the engine running and I could still rotate the wheel. I could feel the brakes dragging but I would expect them to totally lock up for this test.
Both sides of the rotor are rusty. I applied the brakes with the caliper off and it did extend. I was able to get it to retract also. The sliding hardware didn't seem like it was tied up. The pads came out pretty easily. I'm going to try new pads, rotors and calipers this week. |
12-13-2012, 07:41 PM | #5 | |
Changing the pads, rotors and calipers did the trick. Brakes are now working fine. I think the problem was hte calipers.
