Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-28-2011, 01:32 PM   #1
mikelj80
I hear water boiling behind the dash? 2002 ram 1500
was running hot so I added coolant. now the gauge is going up and down slightly and the heater doesn't blow hot air. a.c. seems fine.
mikelj80 is offline   Reply With Quote
Old 07-28-2011, 07:27 PM   #2
jamesslcx
Re: I hear water boiling behind the dash? 2002 ram 1500
HI mikelj80, you probably have an air pocket in the cooling system, keep overflow tank checked and add coolant as needed. Does your engine have a bleeder valve? Sound like you may have a leak.
jamesslcx is offline   Reply With Quote
Old 07-29-2011, 05:29 PM   #3
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
I've read of folks "burping" their cooling system by positioning the front/passenger side of the truck much higher than the rest of the truck with the engine running cold & the radiator cap off, keeping the radiator topped off until the engine gets to normal running temperature, then installing the radiator cap.
A bad radiator cap can keep the cooling system from building normal pressure too.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 07-29-2011, 07:55 PM   #4
dksram
Guest
Posts: n/a
Just remove the radiator cap while cold and start it up. Let the engine get to operating temps and add more water/antifreeze.
You have air in the system and you will continue to hear it until you get rid of it.
If it continues then you have a leak in the system.
Old 08-16-2011, 03:32 PM   #5
angus10
+1, that's how it's done. It's a PITA to get the air out of the system on these rigs.
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
angus10 is offline   Reply With Quote
2002 Ram 1500 Noise During Ignition gjdls95 Ram Pickup | Ram SRT10 3 07-28-2011 02:00 PM
Running water behind the dash board North_star Eclipse 2000+ 0 03-31-2010 01:34 AM
Instrument Custer Change 2002 Ram 1500 jdb1941 Ram Pickup | Ram SRT10 2 12-18-2006 10:47 PM
Where is the amplifier that powers the speakers on the 98 dodge ram 1500 quad cab? RAMHEAD Ram Pickup | Ram SRT10 0 07-09-2005 10:25 AM
2002 Ram 1500 4.7, Weird Sounds condor63 Ram Pickup | Ram SRT10 3 02-25-2005 04:26 PM
