| Latest | 0 Rplys |
07-16-2011, 07:52 AM | #1 | |
Torsion Bar Help!!!
Ok, I messed up royally on the '76 Eldorado. When removing the torsion bars, I was in a hurry and did not mark the relationship between the key, torsion bar and control arm. Now I have my Kanter front end kit in hand and don't know how to install the torsion bar the right way. Any help??
07-16-2011, 04:47 PM | #2 | |
A990 racer
Re: Torsion Bar Help!!!
Can we assume no shop manual? Key being the rear anchor?
07-16-2011, 05:18 PM | #3 | |
The workshop manual says to "mark the relationship of the torsion bar to the adjusting arm (which I called the 'key')" and "mark the relationship of the torsion bar to the lower control arm". This is the second one I have done, so I jumped in like I knew what I was doing and overlooked the simplest thing. I hope someone out there knows what angle the adjusting arm should be to the control arm on the torsion bar.
07-16-2011, 05:29 PM | #4 | |
Master Connector
Are there any marks or indicators on the arm, or torsion bar?
If not, you could mark the other side, then disassemble it, and see where it sits with no tension on it. Then use that as a guide to do the side you didn't mark.
07-16-2011, 08:57 PM | #5 | |
No marks and both sides have been disassembled
07-16-2011, 09:22 PM | #6 | |
Master Connector
Doh, so when you said you had done one before, you meant another car, not one side. My brother did this once on a Subaru, but I can't remember how we fixed it. How clean are the parts? Is there anything to indicate where they may have sat previously?
07-17-2011, 07:49 AM | #7 | |
Oh yeah... big 'DOOOOOHHHHH' .... i did one about 10 years ago. There are hexagonal ends that fit into the key and the lower control arm. I'm think I may need to try the truck/suv aree as those guys are always messing with the torsion bars and changing keys to raise or lower the truck.
07-17-2011, 03:28 PM | #8 | ||
Master Connector
How hard is it to change the torsion bar setting once it's all put together? If it's not too hard, you can always reset the ride height on some flat ground with a tape measure.
07-17-2011, 07:54 PM | #9 | |
Not difficult, just tedious work. You must insert the torsion bar into the lower control arm and into the adjusting arm rearward. It is hexagonal, so I may be off 60% or so if I get it just one off. I don't think there is 60% of adjustment in the key (adjusting arm).
07-18-2011, 12:08 AM | #10 | |
Master Connector
Is it hex at both ends? Or splines on the other?
If it's hex at both ends, then you have a very limited number of positions you can install the arm in.
Thread Tools | |
