| Latest | 0 Rplys |
06-22-2011, 03:31 PM | #1 | |
A/C problem
I have a 2001 dodge ram 1500 pickup . When I turn the Air conditioning on it works OK , when I accelerate on the highway the air blows through the top ( defrost area). When I release the pedal you can hear a damper close and it blows through the vents again. When I accelerate it blows through the defrost area again. I've seen a few posts here that indicate a possibility of a vacuum line under the battery but I don't have cruise control and I think that is what those were talking about. I seemy main vac line off the intake and it has several check valves but they seem to be ok. Also the tiny vac lines seem ok also. Any suggestions on what else or where else to look?
Thanks! Jeff |
06-22-2011, 10:27 PM | #2 | |
AF - Advisor
Re: A/C problem
There's a little crack in one of those vacuum lines, you might re-check them.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
06-25-2011, 10:14 AM | #3 | |
Re: A/C problem
Thanks Chris! I'll check them again. Wondered if the check valves might be bad, I'll check those too.
Jeff |
06-25-2011, 11:45 AM | #4 | |
AF - Advisor
Re: A/C problem
Good idea on the check valve check, they should hold the ac door(s) vacuum up during low vacuum/acceleration periods.
Thread Tools | |
