| Latest | 0 Rplys |
06-03-2011, 04:08 PM | #1 | |
91 Ford Escort Lx Engine shuts off while driving.
I have a 91 ford escort and about 2yrs ago the motor would turn off while i was driving (around 45 to 60 mph) and the dashboard would light up and the needles would peak. then the motor would turn back on and everthing would be fine. I let a friend take a look at it and he said it was a AC sencor. I did not fix the problem cuz it happened at random and the sencor is about $100. I let the car set for about 3 week and now it will not start. Is it the sencor and if so how do i fix it?
06-04-2011, 07:17 AM | #2 | |
Re: 91 Ford Escort Lx Engine shuts off while driving.
Hmm... hard to say what it is with the info given.
It is unlikely any A/C component is causing the engine to die, but there still may be something wrong with the A/C. You say the engine would start again... I will assume you don't mean it would start again on its own, without turning the key... because that would just be plain weird. Two things come to mind. 1. A problem with the timing 2. A vacuum leak. |
06-04-2011, 08:20 AM | #3 | |
My guess is bad ignition switch. I doubt the A/C has anything to do with it.
Nevada Tumbleweed |
06-04-2011, 06:11 PM | #4 | |
Make sure the fuel pump is coming on for a second or two right after the ignition key is turned on. If it isnt, it could be a bad ignition switch (the electrical part, not the keylock part), or a bad fuel pump relay. However, bad ignition switches are fairly common on Escorts, while the fuel pump relays are pretty reliable.
