Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-23-2011, 11:00 AM   #1
steve porter
97 tahoe backfires when cranking, no start
bought a 97 tahoe for a killer price. the guy was no mechanic. said that it was running fine. the next day whent to start and nothing. all he did is replace plugs and wires and fuelfilter. i towed it home and procedied to fix it. i have rebulit one of these engines before in my 99 suburban, so i am familair with working on it. when you try to start it it will turn over fine for a min and then act like it is out of time and backfire from the intake, and also load up and not turn over. i have replaced the cam and crank postion sensor, and nothing i unpluged the ingtion module and it turnover just fine no problem just would not start. i replaced that and it did the same as before . so im lost now i have cleared codes, it has blue spark , fuel, not sure on pressure yet im checking now. i try to spray starting fluild in to intake and it just backfires and starts a flame. need some info please ty. i need the tahoe for school ty again
steve porter is offline   Reply With Quote
Old 04-23-2011, 11:51 AM   #2
mcmalloy
Re: 97 tahoe backfires when cranking, no start
Is it a vortec engine,
mcmalloy is offline   Reply With Quote
Old 04-23-2011, 12:26 PM   #3
j cAT
USING STARTER FLUID UNLESS YOUR A PRO CAN BE DANGEROUS ! only a 1 second spray no more.....
since the plugs/wires were replaced then it would not start remove the wires/plugs inspect for defects including resistance of the wires..then using a diagram reinstall the plug wires correctly..this is a 5.7L engine correct ? remove distributor cap at this time and check for defects and the distributor for defects like the cam gear or the distributor bearings.
cold start you need 62-65 psi of fuel pressure use a guage.
if 58 psi it may not start ..............
j cAT is offline   Reply With Quote
Old 04-23-2011, 12:57 PM   #4
steve porter
it is a vortec model. i tested the fuel pressure and at key on it went to 65psi and bled off to 0 fast. at cranking it is fine but when you stop it bleed to 0 fast. i pulled # 1 plug and it is fuel fouled. as i had the #1 plug wire off and was cranking it was cranking fine with no backfire from intake. put on plugwire and it started to backfire from intake again going to put a new cap and rotor on and new plugs also. any suggestion on the fuel leak down ty
Old 04-23-2011, 05:44 PM   #5
777stickman
Fuel press bleed off could be the press reg or the check valve in the tank sending unit.
Back firing could be improper plug wire routing, cracked dist cap, bad rotor, ign timing off, valve timing off, valve adjustment off, etc, etc.
Too bad you cleared the codes. Would be nice for us to know what they were. For future reference, clearing the codes does nothing to make the motor run better.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Old 04-23-2011, 06:46 PM   #6
Stingray11
I would start with a new cap and rotor. I have seen a lot of those on both the V8 and V6 Vortec engines cause no starts with your description.
David
Stingray11 is offline   Reply With Quote
Old 04-23-2011, 06:59 PM   #7
j cAT
if the engine is getting flooded the loss of fuel pressure with shut down of fuel pump to zero fast maybe injectors/regulator leak...check these out first. then going to the fuel filter hook up pressure guage. with no injectors or regulator with key on then off fuel pressure should hold ..if it rapidly falls then you know fuel pump check valve is defective..NEED NEW PUMP..
MAKE SURE THE PLUG WIRES ARE CORRECTLY INSTALLED..ETC..
Old 04-23-2011, 07:44 PM   #8
steve porter
well when i ran the scan there was no codes so i took back the $300 CODE READER and got my money back. went and bought a new fuel pressure reg. and gaskets to take the inlet plentum off after taking that off i found that the spider was burnt on a couple of the arms so i replaced it and a new reg. also bought new plugs , cap, and rotor. getting ready to finish it up now will post what happen. im also going to reset the timing in it again or see if it is off or not. ty
Old 04-23-2011, 10:21 PM   #9
steve porter
got it running now thanks for all of your help out there now i need to relearn the crankshaft postion sensor and reset timing. runs great thank again
Old 04-24-2011, 08:56 AM   #10
j cAT
good troubleshooting ! you should be fine with what components you replaced for a long time.
I would change the oil very soon...get all that damaged oil out of the crankcase..even do a 2x oil change just to be sure you get all the sludge out of the engine, fuel will break down the sludge as well as damage the oil with poor lubrication.
Old 04-24-2011, 09:41 PM   #11
Stingray11
+1 on the oil change!
Old 01-07-2019, 06:44 PM   #12
DRyan
Im have the same problem mine backfiring though the top blowing the black cover off the says Vortec. I'm leaning towards your fuel pump. But it's a two door and has a 1\2 tank of gas I need to confirm this thought. It's was running fine then went out to go to work one day and nothing just turns over and caughs and hecups . I did try a little gas in the carb thing but nothing. what's the spider and burnt legs the last guy spoke of?
DRyan is offline   Reply With Quote
Old 01-08-2019, 09:00 AM   #13
maxwedge
A990 racer
Check the fuel pressure, you need 60-65 psi.
maxwedge is offline   Reply With Quote
Old 01-08-2019, 09:59 AM   #14
j cAT
change the fuel filter .
99 tahoe no spark or start mylows10 Tahoe 4 04-18-2011 11:48 AM
Will not start (sort-of randomly) caffeineaholic Caprice 7 08-04-2010 08:13 PM
01 tahoe starter pre cranking/stuck robbv Tahoe 9 01-09-2010 07:04 PM
97 Tahoe won't start. Cranks, has no spark rookieshaper Tahoe 2 02-24-2009 09:40 AM
98 tahoe cranks starts after second key cycle chevelleray Tahoe 2 12-03-2007 10:09 AM
