| Latest | 0 Rplys |
03-08-2011, 06:52 AM | #1 | |
Doing front shocks is that much harder
2003 Chevy s 10 4 wheel drive Vortec motor I did the back shocks very easy to do how hard is it to do front shocks
03-08-2011, 11:44 AM | #2 | |
Re: Doing front shocks is that much harder
With limited knowledge about S10 4x4's , I'd say it shouldn't be anymore difficult than the rear shocks .The front has a tube shock just like the rear - correct ?
" Sometimes I grow so tired " |
03-08-2011, 12:02 PM | #3 | |
The RustBuster
It's been a while, but yes the old Blazers had monotube shocks all around. If you can wrap the old shocks with heavy wire like an old hanger or good rope, you can keep the length short, then unbolt the top or bottom and drop the control arm with a jack, they come right out. You can get the new ones in if you wrestle the length down a bit again using old hanger wire (a friend helps), but wear safety goggles and wrap it around the ends well. Install in place, raise the arm to bolt the other end, and cut the wire to release.
Not using wire/rope is more fuss but no fear of breaking wire/rope. Hope this helps!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
03-09-2011, 01:08 PM | #4 | |
I may be wrong here but most GM's have a rubber flap under the hood on each wheel well above the shocks where you can get to the top of the shock. If there is enough clearance you can pound a 1/2 " deep well socket to the nut on top of the shock - then using as many socket extentions as possible, yank the nut back and forth until the top of the shock bolt breaks off - if this is unsuccessful then jack the vehicle up, remove the tire and using all the appropriate precautions cut the bolt off with a sawsall. Then its just a simple task of unbolting the bottom of the shock and letting it drop down.
