Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse 2000+
Old 01-17-2011, 12:05 PM   #1
turbo321
clock removal
how do you the dashboard clock on a 2004 mitsubishi eclipse
turbo321 is offline   Reply With Quote
Old 01-17-2011, 01:49 PM   #2
turbo321
Re: clock removal-correction
how do you remove the dashboard clock from a 2004 mitsubishi eclipse?**
Old 02-01-2011, 10:21 PM   #3
zeroeclipse
zeroeclipse's Avatar
Re: clock removal
you take the plastic housing and just pull it towards you its hard but it will come off make sure you get all the little metal clips holding it on so you can put them back on.
zeroeclipse is offline   Reply With Quote
Old 03-19-2011, 02:33 PM   #4
MiseryMissy
Re: clock removal
I'm fairly certain you have to remove the radio dash cover first.
Under the center, below the HVAC there are two screws at both corners, remove the screws and pull that large piece forward and you can get access to the entire system there.
MiseryMissy is offline   Reply With Quote
