| Latest | 0 Rplys |
12-14-2010, 05:15 PM | #1 | |
Obd
Check engine light is on and i went to have my codes read from the mechanic that does work for me when i can't. He said they coudn't read the codes, the obd had power but the machines couldn'r read it. They tried 3 different OBD machines and still couldn't get the codes.
Any thoughts on this, anyone else had this problem.. 01 windstar, 112k miles |
12-22-2010, 11:29 AM | #2 | |
Re: Obd
Do you have a scanner? If so, what does your scanner say? I currently have a similar problem. Mine reads "link error" when it tries to connect. I'm troubleshooting it now. There are posts on the forum that say some of these issues can be from leaking brake switches and other strange occurrences.
Please keep me informed if you find out a solution and I'll do the same. Mark |
12-22-2010, 02:45 PM | #3 | |
Re: Obd
No i don't, this was at the shop where i take it to sometimes, it did this once before and then i took it back a week later and it worked....
Then 2 weeks later for other work and it wouldnt work?? They used 3 different scanners. All were differnt brands.. |
12-22-2010, 04:27 PM | #4 | |
Re: Obd
The most likely problem is fuse #17 being blown. If that is not the problem, get back to us ... since you have given your model year, someone will likely be able to help.
01-02-2011, 12:22 AM | #5 | |
When they connected to your vehicle, did the scanner turn on? If not, it's a blown fuse, as 12oz. noted. If it does and simply can't connect, you may have a network or computer issue. Read my recent post on how I tracked down my problem. It would be really nice if you had a scanner handy. Maybe you can borrow one from a buddy or get one as a loaner tool from a parts store.
Mark |
01-17-2011, 02:16 PM | #6 | |
Re: Obd
Took it back and one scanner didn't work but another did... Weird.. They did check the fuse, it was working!
01-17-2011, 08:44 PM | #7 | ||
Re: Obd
I forgot to forward what I found out on mine. Mine turned out to be a marginal ABS module. I had tried for months to connect to mine and it would just say link error. I got serious about troubleshooting and started disconnecting all of the other modules that use the same two data wires that connects the DLC connector to the PCM. The first one I tried was the ABS module and it immediately connected. Unfortunately, I reconnected and it still worked. I left it alone for a while and it would always connect....until last week. I went out and it gave me the link error again. I disconnected the ABS module connector and was able to connect again. ABS modules being as expensive as they are, I'm sort of trying to decide what I want to do. I do have access to a Windstar that I bought when the engine seized. I'm going to pop the ABS module out and put it into mine and see what happens. Just thought I'd relay my findings. Mark |
01-18-2011, 03:41 PM | #8 | |
Re: Obd
Is that why my ABS light is on?
01-18-2011, 10:44 PM | #9 | |
Re: Obd
Not necessary, it could be caused by a bad wheel sensor or bad abs pump. You can disconnect the abs module, and see if you can connect the code reader.
01-18-2011, 11:35 PM | #10 | ||
Re: Obd
The ABS module is located underneath the vehicle, just below the driver. There is a plastic cover that is bolted in place over it...it'll have to be removed. The connector is sort of tricky because there is a latch that must be slid sideways before the connector will back out. Disconnect it and I bet you can connect to your OBD. If not, let me know and I'll get you the other modules that connect to your OBD wires. Mark |
01-22-2011, 12:12 PM | #11 | |
Re: Obd
Thanks for the posts guys! for some strange reason it is scanning fine now (not complaining)!!
01-30-2011, 02:54 PM | #12 | |
Re: Obd
If i disconect the ABS module and the OBD sensor connects then is it a bad abs module??
It is weird, the scanner will connect on the small cheap one's but when you hook it up to a better scanner it will not connect?? |
01-30-2011, 03:46 PM | #13 | |
Re: Obd
ABS module and PCM share the same twisted pair of network wires to connect. When there's too much noise in the ABS module, it can't connect. It happens sometime when ABS light is ON.
It's rarely caused by a bad module, but usually caused by a bad ABS sensor. Don't replace the module, just disconnect it to scan codes.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar. |
02-01-2011, 11:47 AM | #14 | |
Re: Obd
Disconnected and still won't scan????
02-01-2011, 11:57 AM | #15 | |
Re: Obd
Maybe you should try to disconnect other modules. Like cruise control, REM, FEM...
