| Latest | 0 Rplys |
09-28-2010, 10:00 AM | #1 | |
1990 Camry 3S...no spark
Changing a valve cover gasket on grandmas' 90 Camry 3S. Car has just over 110k miles on it and runs flawlessly...until now. Took it to the local car wash to give the engine bay a little cleaning due to the leaking valve cover gasket. I tried to not soak the distributor, MAF, ignitor etc on the drivers side of the engine bay as most of the leaking was on the backside of the head on the pass. side. I KNOW I got the distributor wet, as some of the oil leak was built up on the distributor housing.. Now it won't start. Towed it home, let it sit and dry out for a couple of days, disconnected and reconnected everything going to the distributor, pulled a plug, grounded it...no spark. Could I have killed coil that easily? I haven't had a chance to pull the cap and test further...I just can't believe that I could have killed the coil that easily...
09-28-2010, 07:53 PM | #2 | |
Resident Chemist
Re: 1990 Camry 3S...no spark
I think it is most likely just a case of water in the distributor. It is difficult to dry it out. Try a heat gun (gently) with the cap off, including the cap itself. It may take a while.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
09-28-2010, 08:04 PM | #3 | |
Could it really be that easy?!!? I haven't had a chance to even pull the cap off and see whats going on in there yet. I've been busy but will try to pull the cap off and use maybe the wifes hair dryer on it...Thanks for the hope!!
10-02-2010, 01:08 PM | #4 | |
Pulled the cap and it was half full of water...not good, considering the coil is on the lower half of the distributor sitting in its own bath. Cleaned the cap and distributor out with contact cleaner, compressed air and fired up just like new....Thanks!
10-05-2010, 10:31 AM | #5 | |
The RustBuster
Hmmm, surprised the main AM2 fuse didn't blow, but congrats!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
10-06-2010, 02:38 AM | #6 | |
AF -Advisor
Dejavu. Identical thing happened to me some years ago on my 87 wagon. Hair dryer did the trick then too. You live and learn.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
