Go Back   Automotive Forums .com Car Chat > Chevrolet > HHR
Old 09-25-2010, 05:30 PM   #1
jim krisher
Question 2.4 cam actuator valve change
I have an 06 hhr with 138,000 miles. Recently the check engine light came on and the traction lock stayed on. The code came back as a bank 1 cam actuator valve low voltage. I purchased both valves and I need to know which cam is intake and which is the exhaust as the valves are specific ( although they look identicle ).
jim krisher is offline   Reply With Quote
Old 12-14-2010, 02:16 PM   #2
slayerwesco
Re: 2.4 cam actuator valve change
they are the same. they work from oil pressure. they are right on top of engine. 10mm bolts. probably will have to use pliers to remove and twist out. a lot of times the screens fall off. double check that, also if there is any debris on screens make sure you change the oil and filter!
slayerwesco is offline   Reply With Quote
2003 eclipse 2.4 cam crank codes check engine light polarisxcr Eclipse 2000+ 9 08-02-2012 05:39 PM
Stratus misses on 1 & 4 titanthree Stratus 3 07-16-2010 02:31 AM
89 Voyager Valve Train 3.0L Nate1169 Caravan | Voyager 0 09-12-2009 01:11 AM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
2.4 cam timing comp PT Cruiser | PT Cruiser Convertible 4 01-11-2005 07:07 AM
