| Latest | 0 Rplys |
09-15-2010, 07:49 PM | #1 | |
1999 dodge rattle
also if you take a can of wd-40 and spray belt/pulleys the noise will stop for a few seconds
09-15-2010, 08:07 PM | #2 | |
Re: 1999 dodge rattle
Now that you sprayed wd 40 on your belts maybe start there and while you have the blet or belts off spin all your pulleys and make sure they do not wobble and are not making any noise. Either way I do not suggest apraying wd 40 on belts, if they where not a problem before they will be....
Visit my blog at : http://automotiveservice101.blogspot.com/ |
09-15-2010, 08:28 PM | #3 | |
ya i know but if tried everything i can think of to figure this out i appreiciate and welcome any ideas or thoughts
09-15-2010, 08:30 PM | #4 | |
What else have you done?
09-15-2010, 09:40 PM | #5 | |
changed waterpump,pwer sterring pump,alternater,idler pulley, belt tension pulley and tensioner, new belt,a/c pump the noise is a rattle squeal noise
09-15-2010, 11:12 PM | #6 | |
Doesn't look like anything left. Did you adjust the belt properly???
09-16-2010, 08:53 PM | #7 | |
AF - Advisor
Take the belt off, start the engine and see it the noise is still there.
Don't run the engine for more than a minute and don't drive it with the belt off.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
09-16-2010, 09:44 PM | #8 | |
09-23-2010, 05:35 PM | #9 | |
ok thought i had the noise fixed when i put on the old belt it seemed tigher no noise for a little while then it started again the only way to stop the noise for a little while is to rub bar soap on pulleys and belt but would like to figure out a permanent fix
Thread Tools | |
