| Latest | 0 Rplys |
08-18-2010, 08:47 PM | #1 | |
Replacing power steering high pressure hose - 1990 Camry DX 4 cyl
I'm replacing leaky power steering high pressure hose on 1990 Camry DX 4 cyl.
I need detailed steps, and the exact tools required. Chilton's doesn't tell how to just replace a hose nor does it state socket sizes, methods, or special tools. Thanks in advance |
08-19-2010, 05:34 PM | #2 | |
Resident Chemist
Re: Replacing power steering high pressure hose - 1990 Camry DX 4 cyl
Download the Toyota FSM here.
Don't expect to have your hand held. Socket sizes are obvious - you try one and once you get a feeling, you can tell by looking and don't have to be told. How to do simple removals are not detailed anywhere. If you need to be told how to remove a bracket when the bolts are pointed out to you, it is up to you to learn or stop there and hire a mechanic. If you are reasonably good with tools and can figure things out for yourself, then you are in good shape.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
08-20-2010, 02:46 PM | #3 | ||
08-20-2010, 03:20 PM | #4 | |
The RustBuster
These forums are helpful to many, but all will usually know enough and have at least the basic tools to perform minor repairs...screwdrivers, socket set, pliers, hammer, jack, wrenches, etc.
I can understand your wish to have all the tools and info upfront and laid out for you, but honestly, none of us have bothered to sit down and write the size of every bolt we touch when we fix something...we have a set of sockets or wrenches handy and we pick from the assortment as needed. But I will note that most mfrs will stick to two or three common head sizes to make eyeballing them easier...usually in 2mm increments. There shouldn't be any major tools needed to replace a PS hose. Primarily a set of metric wrenches (one end closed and the other end open) from 10-18mm in size (all Toyota fasteners are metric sizes). You'll probably want a drip pan or other large collector to catch any fluid that comes out when you disconnect the hose, and some paper towels to wipe up any spills, your hands, tools, etc. Disconnect the lower one first so that any fluid from the pump will drain out. Then the upper hose connection. Reverse it for installing the new one. Should only be hand tight on the connections. Start the engine, check for leaks, and top off the fluid reservoir as needed with new fluid. Hope this helps and welcome to AF!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
08-20-2010, 06:08 PM | #5 | ||
Resident Chemist
If your expectations of these forums is different from mine, then I guess we will have to agree to disagree. Brian R.
08-27-2010, 02:48 PM | #6 | |
I was hoping to hear from someone who had actually done the repair.
I've had lots of arm chair mechanics tell me to take it off and put a new one on doing the reverse, not detailing methods or approaches or tips. Perhaps this is not a hands-on type forum but how was I to know? I've been on forums for other cars and step-by-step photos were commonly posted. I appreciate the link to the repair book. Our local library has a similar one accessible through their website, something to keep in mind if you ever can't find one. |
08-27-2010, 09:56 PM | #7 | |
The RustBuster
Here's how I'd look at this...if a user had done this repair and felt that the FSM didn't give enough info or missed something, or they found a better way, then they would have posted directions & pics to help. Since there aren't any such posts or replies to your query, then the job is straightforward.
Of course, if for some reason you do have a problem, we'll do what we can (short of coming to you) to help. Good luck! 8900b/MR2 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) |
