| Latest | 0 Rplys |
F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
07-04-2010, 11:57 PM | #1 | |
Bleeding air out of cooling system
92 F150 4.9 4X4 (straight six)
Stepson just bought this truck Friday from a person (no take backs). He doesn't get his actual license until next week, so I'm the one who drove it home (which took about four hours). It never overheated while I was driving it. When we got up to the farm, he took it out to drive it around the farm and very quickly it started to overheat. He said the only thing he did was put it in four wheel drive. The overheating was a gurgling noise and it was pushing into the reservoir. The temperature gauge was acting funny also. It would show no heat while the truck was running normal and then when it would overheat it would go up to about halfway. Any ideas on that? It's been overheating ever since then. Today we replaced the thermostat but that didn't help. I want to bleed the air out of the cooling system, so my questions are... is there a bleeder valve on the cooling system? does anyone have a procedure that has worked well for them to bleed the cooling system on this era of F150? I've heard of parking on a slight hill making sure the radiator cap is the highest point and running it like that with the top off, stop, fill, repeat. Is that my best option? Thanks guys, my stepson and me appreciates any suggestions or advice. |
07-05-2010, 05:39 PM | #2 | |
Re: Bleeding air out of cooling system
You should probably start looking for a coolant leak. It shouldn't loose coolant. As for bleeding, the truck on an incline with the cap off should be sufficient to bleed it.
07-05-2010, 10:50 PM | #3 | |
I haven't really noticed a coolant leak. I was just hoping to get any air out of the system.
Anyone have any ideas about what could be causing the overheating? Changed thermostat. Bled air out. Water is flowing so not the pump. Doesn't seem to be losing any fluid. Temperature gauge seems to be messed up. Any thoughts would be welcomed. Gonna check the radiator's fins tomorrow as good as I can. Maybe he did something and now they're all bent up and not flowing. |
07-12-2010, 08:08 AM | #4 | ||
If it isn't losing fluid, then it isn't flowing right... something is blocking it somewhere. How bad did it overheat? |
07-12-2010, 03:46 PM | #5 | |
seems it was the radiator. we replaced it and the overheating problem is gone. I just hated replacing parts without being sure of which part. After taking out the old radiator, it was pretty obvious it was a problem. The fins just kind of flaked off if you rubbed them.
