| Latest | 0 Rplys |
06-12-2010, 01:29 PM | #1 | |
1995 Dodge van 2500, ingnition problem. Help.
I have a 1995 dodge van 2500 with an electrical proble, when I insert the key and turn it, the fuel pump relay does not click or come on. There is no voltage at the fuel pump relay. I have to wait at least 30 minutes with the ingnition switch on, then the relay stars clicking repeately, after a few minutes the relay stays still and there is steady voltage at the relay. After that I can turn the van on. I already replaced the relay and the ignition switch. What could be wrong?
06-12-2010, 02:08 PM | #2 | |
Re: 1995 Dodge van 2500, ingnition problem. Help.
I've seen this before, the problem is a bad computer (PCM). Usually if you first warm up the computer with a hairdryer, the engine will start almost immediately. That's the easiest way to verify that it's the computer.
06-12-2010, 06:14 PM | #3 | |
I will definetely try the hair dryer, alloro. Thanks.
06-15-2010, 11:35 AM | #4 | |
Heating up the PCM did not work, any other toughts? What else should I check?
06-15-2010, 04:50 PM | #5 | |
Your problem is still the PCM. It just would've been nice to be able to verify it for your own piece of mind.
