| Latest | 0 Rplys |
05-08-2010, 10:14 AM | #1 | |
Bouncing front end
Hey guys.I got a new problem.I got my back brakes done and my gas millage is back to normal.Thank god.It was in fact the rear drivers caliper seizing.
Now I have another problem.I have this bouncing feeling in the front end when I"m driving between 20-35 mph.I think its coming from the front.At least it feels that way.I know I could have a broken band inside the tire that can cause this. I"m going to take off the front tires and ride on the donut just to see if the bouncing goes away.If it does then I know its the tire.If the bouncing doesn't go away what else could cause this?Thanx guys. |
05-08-2010, 06:16 PM | #2 | |
Re: Bouncing front end
A bad shock, you could move the tire around also and see where it goes. When you lift up the car push on the wheel from right to left and top to bottom and see if their is any play
2000 Intrigue GX 3.5 110k Mods: Cold Air Intake, Polished Intake Ports, 12inch front Brakes, Dorman front Swaybar Last edited by dizzle1; 05-09-2010 at 12:59 AM. |
05-08-2010, 07:04 PM | #3 | ||
Banned
Play in the wheel will be from ball joints or tie rod ends. Vibration is usually from a bad tire. |
05-09-2010, 01:04 AM | #4 | ||
2000 Intrigue GX 3.5 110k Mods: Cold Air Intake, Polished Intake Ports, 12inch front Brakes, Dorman front Swaybar |
05-09-2010, 07:52 AM | #5 | |
O'K guys.I took the front drivers side tire off and replaced it with my spare but it was really a waste of time to do because as soon as I took the tire off I could clearly see it has more wear on the inside and a band is broken in the tire.
I have a split in the tire and the mesh that makes up the band is ever so slightly showing through the tire.When I drove it with the spare the bouncing was gone so It's defenatly my tire so I will be replacing the front ASAP. |
05-09-2010, 09:12 AM | #6 | |
Yeah definitely don't drive it until you get that tire fixed..seems like there's always a bit of grace when we don't know exactly what the problem is, but when you know what's wrong and keep pushing it, seems like thats when bad stuff happens haha.
I'd rather drive with the donut than use that tire, although Id rather have the donut on the rear personally. If youre strapped for cash, check out your local Craigslist, you might be able to at least find a functional tire that isnt falling apart that would get you by for a little while.
2000 Oldsmobile Intrigue 3.5 DOHC V6 Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners 1986 Jeep Cherokee 2.8 V6 |
05-09-2010, 12:18 PM | #7 | |
Dont forget about the why your tire was worn that way.You should probably check the other side and tires as well you may need an allignment. If the allignment is off and you put a new tire on you'll just ruin that tire.
05-09-2010, 10:28 PM | #8 | |
Yeah...I know it's the alignment.I've needed to get it done since I bought the car but haven't had the time or money to get it done.I rotated all the tires today to get that bad tire in the back.i think they have been rotated before for wear cause the damn thing rides like a hummer with knobby tires now.
Thread Tools | |
