| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
04-23-2010, 05:40 PM | #1 | |
1998 chevy blazer-starter
i have a 1998 chevy blazer 4x4 withe the 4.3 vortec
the starter spins but does not engage with the flywheel.......engine will not start? could this be the starter itself or possibly the solenoid? |
04-23-2010, 06:54 PM | #2 | |
Re: 1998 chevy blazer-starter
well, the starter/solenoid is sold as one unit.
try smacking it with a hammer, or a large ratchet. a few good bangs should bust it loose. that will tell you for sure if that is the problem. or, you can take it out, which is pretty easy, and take it to autozone and have it tested. you'll be able to see if it is moving out to hit the flywheel, as it should.
2001 Chevy Blazer 4.3L 5 speed manual Alpine deck, Type R 12in. sub. 145k miles 1997 Pontiac Sunfire 2.2L automatic trans 146k miles |
04-23-2010, 07:51 PM | #3 | |
Advisor/Moderator
If the starter motor spins but does not engage the flywheel/flexplate, it could also be the starter drive which can also be serviced separately.
http://stores.oksap.com/-strse-519/N...For/Detail.bok
You have to know how it works, to figure out why it doesn't. |
04-23-2010, 09:03 PM | #4 | |
i just had this starter rebuilt with a new solenoid put on it..........and it still doesn't work! these people piss me off 'cause i paid them for the service & it's a piece of crap! lol
04-23-2010, 09:11 PM | #5 | |
Advisor/Moderator
The drive and the solenoid are two different things. The solenoid pulls the drive into the flexplate/flywheel. The drive has clutch that only turns in one direction on the starter motor shaft. If you can hear the solenoid move, (clunking sound just as the starter motor starts to spin), the drive is bad. Don't waste your time with those starter tester machines, they don't test the drive.
04-24-2010, 12:28 PM | #6 | |
the only problem with this assembly is that the drive is not engaging with the flywheel.........the starter spins like it's suppossed to.........hope i spelled that right! lol..............dunno!
