Go Back   Automotive Forums .com Car Chat > Panoz > GTRA / GTWS / GTS
Old 12-20-2009, 07:40 AM   #16
Jim woodruff
Jim woodruff's Avatar
Re: Rear end re-seal
Originally Posted by Panoz26 View Post
_____________________
resurrecting an old post:
OK, I have a small amount of "fluid" coming from my rear passenger hub - after reading above, it seems as if I need to replace the seals on the hub(s) as well as the Diff seals - is this correct?
thanks
Devin.
If you follow David's instructions above you will have no problems. I did it and I could screw up a one car funeral. The only thing I did different was to coat the inside of the tube with a rust inhibitor.
Jim woodruff is offline   Reply With Quote
Old 12-20-2009, 06:44 PM   #17
David Eastman
I just reread this post and I have two more tip to install the axles seals. Instead of trimming the rubber off the outside of the seal I made a ring compressor ( like a piston ring compressor) out of .010 shim stock and a hose clamp. Installed the seal in the tube and taped it with a block of wood. They slid right in. Gary Jones gave me a tip. He said to pack grease inside the seals. He said this will help reduce heat.
David
David Eastman is offline   Reply With Quote
Old 12-20-2009, 07:00 PM   #18
Panoz26
Panoz26's Avatar
where did you purchase the HUB seals, I was going to call Coleman in the AM to try and tell them what I need..... diff, I found from your ealier post
thanks
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Panoz26 is offline   Reply With Quote
Old 12-21-2009, 04:34 PM   #19
David Eastman
I think I got them from Speedway.
Old 12-22-2009, 08:46 AM   #20
Panoz26
Panoz26's Avatar
this is what Coleman advised me to order - so, I did.
150-503 Seal, 2 5/8 Diameter, 3 Pcs.
19753 Seal, Impala Hub -- front
CR-23755 Seal, Hub -- rear
We shall see.
Old 12-22-2009, 06:10 PM   #21
Gatorac
Gatorac's Avatar
I would pull the chunk and see what you have in there before ordering anything. You may have the newer style "Seals It" seals.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Gatorac is offline   Reply With Quote
Old 12-29-2009, 06:05 PM   #22
Panoz26
Panoz26's Avatar
OK - Chunk is out and seals are shot - also wondering how in the heck I am supposed to put the metal seals back in.
(Pictures of the aftermath):
Old 12-29-2009, 07:32 PM   #23
eric1h
man, that is some serious carnage!
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
eric1h is offline   Reply With Quote
Old 12-29-2009, 08:10 PM   #24
David Eastman
Devin, PM sent.
Eric I bet your seals look just like Devins.
David
Old 12-29-2009, 08:18 PM   #25
eric1h
Originally Posted by David Eastman View Post
Devin, PM sent.
David
Probably, Now, I had paid gary Jones to swap mine out when i bought the car, so mine may look a LITTLE better, but probably not much
Old 12-29-2009, 08:33 PM   #26
eric1h
Devin, this would be a good time to swap in some 3.90 gears ;-)
Old 12-30-2009, 08:05 AM   #27
Panoz26
Panoz26's Avatar
That's a good idea.... Ill start shopping this AM.
Whilst we are on this topic - I've been reviewing several gear oils and weights. The redLine shockproof looks like the ticket, however, I'm not entirely sure if it's too much and should stick with the 75w90..
thoughts, comments, laughter, etc....
Old 02-06-2016, 10:17 AM   #28
JCJ51
Originally Posted by Cobra4B View Post
Got the new tripple seals from Panoz... might as well have it redone while she's down for the mods right now.
How did the new seals work? I'm looking at purchasing a used 2006 GTS and there's small leaks on each end of the diff tubes and going on to the rear rotors. Owner's mechanic says this is normal??? Thanks
JCJ51 is offline   Reply With Quote
Old 02-06-2016, 04:47 PM   #29
CMPanoz
Not only is it not normal, it's not safe.
The actual tube seals are easy to remove and install. Call Panoz, they can save you a lot of time by supplying the correct seals and giving guidance.
Panoz GTWC 2
Panoz GTWC 3
Panoz GTS
CMPanoz is offline   Reply With Quote
Old 02-07-2016, 12:26 AM   #30
JCJ51
Thanks for the quick reply. According to Panoz tech folks the diff tubes are supposed to be dry.
