Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-18-2016, 01:30 PM   #31
sdillon030976
Re: 02 ram stalls shortly after fuel cap is opened
ok battery passed test. so its the computer of ignition switch.. I don't have the money for a computer right now so I will update as I can.. thanks everyone
sdillon030976 is offline   Reply With Quote
Old 08-28-2016, 03:10 PM   #32
sdillon030976
a dumb question.. after I buy this computer hopefully in the next 2 weeks, am I still going to have to have my truck programmed for the key?
Old 08-28-2016, 07:56 PM   #33
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
If the key operates the keyswitch now, it shouldn't affect the computer except supply electricity to the system.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
The Following User Says Thank You to Chris Stewart For This Useful Post:
sdillon030976 (08-28-2016)
Old 09-10-2016, 10:17 AM   #34
sdillon030976
ok heres my update. the new computer finally got here.. installed it and the truck fired right up.. everything is good.. I did notice that when the key is on but engine not running the check engine light still flashes 12 time..
Old 10-12-2016, 05:57 PM   #35
the61
How come no one comes back and answers what the problem was? That is about the only complaint I have with a forum. thanks for the one come back.
the61 is offline   Reply With Quote
Old 10-12-2016, 06:02 PM   #36
sdillon030976
I did in my situation it was the computer, the flashing light is alerting you that you have a problem with emissions system. my case was a bad catalytic converter, the down flow 02 sensor and a hose leaking by emission canister. I have no codes or check engine lights at the moment..
The Following User Says Thank You to sdillon030976 For This Useful Post:
the61 (10-12-2016)
Old 10-12-2016, 06:15 PM   #37
the61
I had a chevy that would just quit going down the road. Believe it or not it was the temp sending unit went bad. Drove me nuts finding that one.
