Go Back   Automotive Forums .com Car Chat > Ford > Expedition
Old 01-11-2015, 10:34 AM   #1
JimConnell
2006 Ford Exp. inside rear noise
My veh. has a mechanical rhythmic clunking noise under the rear passenger vent window and above the rear wheel well.
This noise is produced only when the rear heater control is turned-on.
It is fairly loud. It does not seem to be the rear window control.
The noise does not seem to be made by something in a fan.
I have operated the rear seat controls and they work fine and don't produce any unusual noises.
I have operated the rear vent-window controls and they work fine and don't produce any unusual noises.
Does any one have any idea what this could be? and how to fix it?
JimConnell is offline   Reply With Quote
Old 07-12-2016, 04:44 PM   #2
Dngrsone
Dngrsone's Avatar
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Re: 2006 Ford Exp. inside rear noise
There are two actuators back there, accessible by removing the tray and cup holder. The top one is the floor air redirect, the one mounted vertically behind the interior panel is the blend door actuator. If you can adjust the rear temperature knob and the clunking goes away momentarily, then it is likely this actuator is broken.
Here is a tutorial on changing that actuator.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
Dngrsone is offline   Reply With Quote
Old 04-21-2018, 08:00 PM   #3
Keg914
I second that. My 2003 had the same problem.
Keg914 is offline   Reply With Quote
