Old 10-25-2006, 02:26 PM   #76
GreyGoose006
Re: are these changes better for all of us?
how much more weight and complexity does an 8 speed tranny have over a 5 speed. even a 6 speed.
seems like the extra weight would offset the performance of having 2-3 more gears.
unless the shifts are lightning quick, there is also time lost between gears, and in slippage to keep the jerkiness out.
GreyGoose006 is offline   Reply With Quote
Old 10-25-2006, 09:11 PM   #77
UncleBob
AF -Advisor
some of the fancy new trannies are casset style trannies, using engine management to shift gears....ie, no clutch operation for a shift. The shifts are roughly .06 seconds....I read somewhere anyway. Not much lost time on a shift.
No clutch packs greatly reduces the complexity....mechanical complexity anyway.
Casset trannies are very compact and not all that heavy....bikes have been using them for decades.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
UncleBob is offline   Reply With Quote
Old 10-26-2006, 11:12 AM   #78
Steel
Steel's Avatar
Looking at the lexus site, it seemes to be your run-of-the mill planetary gearset type auto. Just with more bells and whistles. And gears.
Steel is offline   Reply With Quote
Old 10-27-2006, 07:02 PM   #79
KiwiBacon
That won't worry your average lexus buyer.
LEXUS = Luxury EXport US
KiwiBacon is offline   Reply With Quote
Old 10-28-2006, 12:47 AM   #80
curtis73
Professional Ninja Killer
curtis73's Avatar
someone on this forum once said that usually, a 7 or 8 speed tranny was really just a 4 speed that used the TC locking as another gear.
1 + slip = 1
1 locked = 2
2 + slip = 3
2 locked = 4
3 + slip = 5
3 locked = 6
ect...
is this true?
seems like BS to me.
Some may do that, but all the new 6+ speed trannys I've seen are all distinct ratios. The TC usually locks up independently of the gears. Whereas TCs used to lock up after reaching top gear, now most of them just generically lock up at X mph. I think Ford's new one locks up at 35 mph unless you go WOT.
Dragging people kicking and screaming into the enlightenment.
curtis73 is offline   Reply With Quote
Old 10-28-2006, 04:56 PM   #81
psychopathicdude
psychopathicdude's Avatar
Originally Posted by curtis73
Ford's new one locks up at 35 mph unless you...
"Can I get a WOT WOT??????"
This kind of mindless drivel will get me back on the dumbass list for sure....I mean, fo sho...
This Space Intentionally Left Blank
psychopathicdude is offline   Reply With Quote
Old 10-28-2006, 10:35 PM   #82
UncleBob
AF -Advisor
he means "new" as in comparing the time line to big-bang intervals
