Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 08-04-2014, 08:09 AM   #1
Black_Blade
Will 04 Caravan fuel pump fit 06 Grand Caravan?
I have a 2006 Grand Caravan 3.8 that just stalled at a set of lights yesterday and have had it towed back to the shop here. I turns over and starts briefly then will die and then just turn over strongly. I cleaned the throttle body and IAC but this did not help any. I connected fuel pressure tester and have no pressure when turn key on or turn it over.
The fuse and relay check out ok, so I'm thinking bad or clogged fuel pump.
I have a 2004 Caravan out back that I have used for other small parts to interchange before and was wondering if anyone knows whether or not the fuel pumps between these two are compatible. Be a lot of work to pull the one off the one in the yard, only to find out its not going to fit. Tried phoning around this morning but its a holiday for most people I guess, so I'm SOL in that regard!
Looking on the Rockauto site and I'm finding some models of pump that fit the 04 are good up to an 07 grand cara, but others that do not...
2002 Dodge Dakota 4x4 3.9L
Black_Blade is offline   Reply With Quote
Old 08-04-2014, 08:39 AM   #2
Azazan
Re: Will 04 Caravan fuel pump fit 06 Grand Caravan?
Is it the 04 6 cylinder or the 4 cylinder
Azazan is offline   Reply With Quote
Old 08-04-2014, 08:42 AM   #3
Black_Blade
Its the 04 V6 3.3L
Old 08-04-2014, 08:54 AM   #4
Azazan
Fuel pumps aren't compatible
Judging from my data base
The Following User Says Thank You to Azazan For This Useful Post:
Black_Blade (08-04-2014)
