Old 09-17-2019, 05:32 AM   #1
GTRfan01
removing chrome
Hello all,
I want to selectively remove some chrome, the inner part of a rim and leave the chrome lip.
my problem is all the chrome removing substances I've used and read about are all liquid and you soak the whole part in it. Impossible to brush on in a precise manner to do the job i want it to do.
anyone with any ideas?
im hoping to find something that is more a paint type consistency so i can brush it on where i want it.
Thanks
GTRfan01 is offline   Reply With Quote
Old 09-17-2019, 06:03 AM   #2
Kjenjak
Kjenjak's Avatar
Re: removing chrome
Interesting challenge…
I've never heard of any product that isn't liquid.
Have you tried masking the lip, with a masking liquid, not tape, and then soaking the part?
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Kjenjak is offline   Reply With Quote
Old 09-17-2019, 08:20 AM   #3
GTRfan01
Re: removing chrome
Thanks that's a good idea, that will be the back up plan if i can't find another solution!
Old 09-17-2019, 10:24 AM   #4
freakray
AF Modelrater
Re: removing chrome
Personally, if I've wanted a painted center I just paint over the chrome, I've never had an issue.
I'd find it hard to believe that anything that's going to remove chrome won't also remove any kind of liquid mask.
AF User Guidelines
freakray is offline   Reply With Quote
Old 09-17-2019, 08:21 PM   #5
GTRfan01
Re: removing chrome
i was very close to just painting over it like normal.
but the wheel centre is to be white, last time it took too many coats to cover properly. and these wheels will loose some detail with too much paint.
Also because the plastic under the chrome is white it made me think it would make painting much easier not having to worry about covering up with white.
Old 09-18-2019, 03:12 AM   #6
malscar
malscar's Avatar
Re: removing chrome
Not sure that will work as the liquid once it starts lifting the chrome from the unmasked area will have access to the area under the chrome. Will just lift it off but attached to the masking agent.
malscar is offline   Reply With Quote
The Following User Says Thank You to malscar For This Useful Post:
GTRfan01 (09-18-2019)
Old 09-19-2019, 05:50 PM   #7
MPWR
Image Hosting Exceeded
MPWR's Avatar
Re: removing chrome
Yeah, I wouldn't expect to find a good method to selectively remove chrome, and leave other areas intact and pristine. I'd be curious to be proven wrong, but in my experience the nature of removing chrome makes it all or nothing.
Like Freakray says, I'd mask the rim (probably with a liquid film) and paint the center. Failing that, strip the chrome, paint the center, mask, and then repaint the rim.
PHOTOBUCKET SUCKS
MPWR is offline   Reply With Quote
Old 09-20-2019, 07:06 AM   #8
stevenoble
stevenoble's Avatar
Re: removing chrome
If you use a white primer first over the chrome it should be relatively easy to paint the centre white..
Steve Noble
stevenoble is offline   Reply With Quote
Old 09-22-2019, 11:55 AM   #9
AAlmeida
AAlmeida's Avatar
Re: removing chrome
Romove all chrome as usual, paint center and use Molotow Liquid Chrome Marker on lip
Almeida... I'm back!
AAlmeida is offline   Reply With Quote
Old 09-22-2019, 01:37 PM   #10
jayll
jayll's Avatar
Re: removing chrome
Maybe set a container on a level surface filled with bleach (or whatever you use to strip chrome) and then dip the wheels up to the line you want to remain chrome.
jayll is offline   Reply With Quote
Old 12-07-2020, 10:29 AM   #11
pirata12
pirata12's Avatar
Re: removing chrome
Use bleach in the gel format. Paint it onto the parts you want to dechrome. Make sure it doesn't get onto the part you want to keep chromed.
I've done this with success on bike fork I wanted some chrome to remain.
pirata12 is offline   Reply With Quote
