| Latest | 0 Rplys |
07-04-2006, 11:23 AM | #1 | |
1979 chateau club wagon help please *Pics*
Hi All,
I bought this van for $250,When i whent to go look at it it started right up and during the test drive felt like it needed a good tune up (10 mile's),so i bought it (REALLY) needing a running car. So here i go.. :P,2 Miles after i bought it on the way home it died at a light...couldint get it started "for 2 light cycles" ,got it started and it was wanting to die..."keeping very little pressure on the gas peddle kept it running" / was that all the way home untill i turned into my driveway and it quietly died... 30 minutes later i got it started and was only able to keep it running by holding the peddle to the floor...and got it home.Next day i went out and it started up fine but the idle was very rough/after it was warmed up i put it in gear and it died...instantly over the next week i replaced the fuel pump/fuel filter/cap/roter/sparkplugs/and a fuse for the blinkers:P , i cheacked ALL hose fitting's and cleaned out the EGR.... (i also cheacked the PCV valve...its fine) after all this i started it up and man was it running GREAT ,i adjusted the idle and it sounded like a new van:P....it even ran while in GEAR! after all that i decided to go for a test drive...put everything back together "EA:air assembily /filter/air hoses/doghouse" and when i started it up after all this it idled like crap again "would run fine in gear/low idle" started going down my diveway "about 120feet" down it died/would not start...after 30 min or so i got it started and it would die when put in any gear exept nutrual. i did get it moved about 30 feet by FLOORING it and putting it into gear "BAD i know"....what cought my atention while doing this is while it was moveing "the 30 feet" it seemed like it was not fireing on all 8 cylinders + was loseing power every 1 of those 30 feet till it died.. after all this when it starts,and runs a little... and you step on the gas i can hear a "sucking" sound comming from the front of the engine "this is with the doghouse off" as this sound gets louder the engine dies...with not even a "putter" BUT if i feather the gas pedel i can get it running smooth "at idle" Any idea's ?:P *PICS ... becouse people have been looking for them... Yup ive read this ENTIRE forum before posting* "56K BEWARE!* http://www.loginscreen.net/images/v1.JPG http://www.loginscreen.net/images/v2.JPG http://www.loginscreen.net/images/v3.JPG Last edited by timmylc; 07-06-2006 at 04:34 AM. |
07-06-2006, 03:30 AM | #2 | |
AF - Advisor
Re: 1979 chateau club wagon help please *Pics*
vacuum leak
Check all the hoses, making sure they are not cracked, missing, incorrectly connected, and properly sealing. Use a can of carb cleaner to spray around to look for a vacuum leak. |
07-06-2006, 04:16 AM | #3 | |
"cracked, missing, incorrectly connected, and properly sealing."
thats what i thought also...THANK YOU for replying... i have this ONE area to cheack tomarro...."front of carb/behind distributer"....that has vacume line comming in and out....etc.... this van has been worked on ALLOT i have 12k worth of recepts ... "engine rebuilt in 1995" etc etc...+ ive found 4 hoses "vacume" hooked to each other+2 vacume tubes on the front of the carb with nothing hooked to them "pluging these with my fingers made the van run even better!...(ive pluged them now with screwes+sealant-getto i know...) next step is hunting down that sucking sound witch im POSITIVE it relates to the whole problem at hand....i shall attempt tomaro VAN IMAGES UPDATED TO *on main post and this one* http://www.loginscreen.net/images/v1.JPG http://www.loginscreen.net/images/v2.JPG http://www.loginscreen.net/images/v3.JPG |
Thread Tools | |
