Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 04-30-2001, 09:44 AM   #1
labguy2776
Post
I have a 93 325i that I have to replace the engine. The problem I'm running into, is trying to seperate the engine from the trans ( i'm unable to get to all the bolts). I have the Hayes book and in the beginning procedures it tells me that the trans will have to be removed from the engine (if i could do that i would already have the car running). I was wondering if I had to drop the trans, so that it could hopefully tilt, and I could get to the rest of the bolts. Or, do I have to remove the trans completely. Any help or information on this would be greatly appreciated. :alien:
labguy2776 is offline   Reply With Quote
Old 04-30-2001, 01:41 PM   #2
enzo@af
Old Mod
enzo@af's Avatar
Send a message via ICQ to enzo@af Send a message via AIM to enzo@af
no suggestions, but what do you plan to replace the engine with? Anything exciting, or just a straight replacement?
I've said it before, I'll say it again. "Nobody does rip and snort like Ferrari"
enzo@af is offline   Reply With Quote
Old 04-30-2001, 02:30 PM   #3
labguy2776
Sorry, just a straight replacement. I wanted to place the new M3 engine instead of just a regular 2.5 L, until I saw the price. (ouch)
Old 05-01-2001, 02:18 AM   #4
GTO-TT/Chev57
GTO-TT/Chev57's Avatar
Hi, It's nicer to undo the top bolts if the trans hanging down at the back. Put a jack under trans and undo the rear crossmember will be better with exhaust and drive shaft off, hope you still got the engine mounts done up.
Slowly bring the trans down just enough to get a long extension and socket on them, and then lift the trans back up and bolt up. Use a small jack to support the front of the trans while you take the motor out, make sure when you lift the motor to clear the mounts you keep the jack touching the trans. Is it auto or manual.
01 Chev Blazer
57 Chev Sports Coupe 383
57 Chev 4dr Sedan 283
56 Chev Stepside 454 Supercharged
GTO-TT/Chev57 is offline   Reply With Quote
Old 05-01-2001, 10:13 AM   #5
labguy2776
Its an automatic. Looks like I picked a tougher job than I imagined.
Old 05-01-2001, 10:50 AM   #6
GTO-TT/Chev57
Hi, With the auto after you undo the converter and are ready to pull it out make sure the converter stays in the auto. Use a screwdriver to push it back in the converter bolt holes and don't rock the motor too much taking out.
The E36 are a little bit hard to do, it always look easyer.
01 Chev Blazer
All purpose cleaner to remove oil, grease, tar... mikecooper General Tools 3 02-15-2011 09:15 PM
I replaced my 325is engine w/90-325is won't star-only-pushing it Louis XI Automotive Articles 0 05-28-2006 06:09 PM
1991 325i Engine route89 General Discussion 0 11-02-2005 09:54 AM
Investigating a 325i engine swap csphere 3 Series 6 09-20-2004 08:12 PM
1987 325i Engine swap CapedCrayola 3 Series 0 07-13-2002 02:04 PM
Bookmarks
Search this Thread:
