Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
View Poll Results: Which Engine is the better for Forced Induction??
D15 5 4.39%
B16A 13 11.40%
D17A 0 0%
B18B 45 39.47%
B18C1 27 23.68%
B18C5 12 10.53%
H22A 12 10.53%
Voters: 114. You may not vote on this poll
Old 01-26-2004, 01:07 PM   #46
SenseiAccord
Re: Which Engine for Forced Induction??
So wait what would happen if u run 12psi to the GSR? All this FI stuff is confusing for me and the battle between engines
SenseiAccord is offline   Reply With Quote
Old 01-26-2004, 01:18 PM   #47
tran_nsx
tran_nsx's Avatar
Re: Re: Which Engine for Forced Induction??
u can can't run 12 psi's on a stock b18c1 (gsr), well u can but there goes your engine.
tran_nsx is offline   Reply With Quote
Old 01-26-2004, 01:55 PM   #48
PWMAN
PWMAN's Avatar
You can run 12 PSI on the internals, but not on pump gas. It will detonate because the compression in a GSR is much higher to begin with than an LS.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
12.37@111.75 MPH
PWMAN is offline   Reply With Quote
Old 01-27-2004, 12:32 AM   #49
SenseiAccord
Re: Re: Re: Which Engine for Forced Induction??
oh yea i forgot about the different compression ratios. Alright thanx people!
Old 01-27-2004, 07:19 PM   #50
F23A4Racer750IL
Originally Posted by whtteg
And just FYI the H22A is the worst motor out of the ones listed in the poll. Even though ppl have voted for it, it is a problem matic motor when boosted on stock internals.
ur sayin the D-series is better for turbo than the H22??
F23A4Racer750IL is offline   Reply With Quote
Old 01-28-2004, 01:56 AM   #51
Thepeug
Quem queritis?
Thepeug's Avatar
Send a message via AIM to Thepeug
This thread is ancient.
Peace, love, and premium octane.
Thepeug is offline   Reply With Quote
Old 01-28-2004, 12:23 PM   #52
tran_nsx
tran_nsx's Avatar
thanks i didn't even noticed.
atleast the question was answered so people don't have to argue about this debate over and over again, especially about the b18b and b18c1. it gets really annoying to see the same freaken thread topics in different forums. the mods should move them all to one forum so everyone is on the same page. one thing that dumbfounds me is the fact that even after i gave proof of the two dynos, why are people still voting for the the b18c1. they must not be reading the posts or they are really ignorant and stubborn headed. as far as how much power can be extracted, there's even dynos of over 650hp coming out of the the b18b, so power is not an issue at all.
Old 01-29-2004, 12:20 AM   #53
Thepeug
Quem queritis?
Thepeug's Avatar
[quote=tran_nsx] it gets really annoying to see the same freaken thread topics in different forums. QUOTE]
I completely agree. Unfortunately, no matter how extensively moderators monitor the forums, it'll always happen.
Old 01-31-2004, 10:28 AM   #54
whtteg
whtteg's Avatar
Send a message via AIM to whtteg
Holy crap this thread has got long I have not popped back in here in a long time lol. Will it ever die?
Not really but I have known more stock D series motors to be boosted with better luck than the H22A. I was mostly talking about in the DOHC aspect, but I would take a D series and boost it before I would boost the H22A
whtteg is offline   Reply With Quote
Old 02-02-2004, 09:11 PM   #55
joecheez
Send a message via AIM to joecheez Send a message via Yahoo to joecheez
Bone stock it goes to the LS...
and I understand this was a stock motor discussion thread and people did not read before voting displacment first. This being said I take issue to bad H22A marks after a built motor at least. I have seen 16 H22A's come out of the two shops in my area (8 and 4) with 9.5-1 JE pistons and numbers like 8PSI 250 HP, 16 PSI with 360 to the wheels, both on pump gas set up to run on the street mostly and at the track on the weekends, mind you all of them sleeved. I have also seen the same ones with 440-650HP on C16 gas with the bigger injectors. He also has a new race motor to take the place of the turbo built GSR which ran an 8.61 at moroso a few months back which had about 670 to the wheels in a tube framed hatchback. The new motor, an H22A to 2.3 like my basic build will produce over 1000 HP to the wheels and they are hoping to achieve high 7's from this H23A DOHCVTECed monster.
Green 95 Accord coupe with a 95 Prelude motor(2/10/01); 2 motor builds later(first 12.5-1 the rings did not seat), it is now a 2.286?(.089 monster bore and sleeved) DOHC VTEC with 9.2-1 JE pistons ready for a turbo T3/4. Cam gears, skunk2 stage 1 cams, crower rods, titanium head parts with a 3 angle valve job and extra thick head gasket.
AEM CAI, 421 DCSports header, Stillen FPR, trunk battery, H&R, tokico illuminas, front/back camber kits, & 215R16 FS GTS.
joecheez is offline   Reply With Quote
Old 02-02-2004, 10:16 PM   #56
whtteg
whtteg's Avatar
The sleeves are the reason I said they were the worst motor to boost. It is just like tring to boost a B20 their cylinder walls are too thin. Yes res;eeving it would be a very, very good move
Old 02-03-2004, 10:31 PM   #57
eckoman_pdx
Honda God
eckoman_pdx's Avatar
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
As whtteg already said, the reason the H22 isn't considered a good motor to boost is because the cylinder walls are thin. The can wobble and crack under too much boost. As he said, the same is true with a B20. A B20 is essentailly a bored out B18B1. Re-sleeving the H22 or B20 is a very good place to start. If you are doing a full motor build, re-sleeving takes care of one of the more things that makes boosting these motors not the most ideal set-up in the world. Re-sleeving a motor and building it up can make almost any of the honda motors worthy of boost, so to speak. However, most people in the scene will never do a full build. Even if they talk about it, it doesn't happen. As a result, the H22 isn't the greatest motor to boost, since we are talking boosting stockers. If your going to build a motor, what motor you build and what you do to strengthen the block, etc...depends mostly on your buget. The H22 can be boosted and make power, thats true. But as whtteg said, if your doing this, re-sleeving is a good place to start. If you arn't interested in building a motor, you are looking to mildly build and boost a motor, the H22 isn't the greatest choice then, since, as we said, the cylinder walls (sleeves) are thin and prone to crack under too much boost.
eckoman_pdx is offline   Reply With Quote
Old 02-04-2004, 03:21 PM   #58
PWMAN
PWMAN's Avatar
Originally Posted by eckoman_pdx
However, most people in the scene will never do a full build. Even if they talk about it, it doesn't happen. .
This happens when people find out how much it is to resleeve the block. LOL
12.37@111.75 MPH
Old 02-05-2004, 02:48 AM   #59
eckoman_pdx
Honda God
Yes, among other things they discover the price on...lol..."what??? you mean it costs money to make my motor stronger??? that's messed up..."...LOL
Old 02-06-2004, 01:14 PM   #60
Miataracer
Miataracer's Avatar
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
good lord... trying to read this whole post has given me a headache!
LS1 RX-7 Zoom Zoom
Miataracer is offline   Reply With Quote
How can forced induction increase engine efficiency? caffeineaholic Engineering/Technical 4 07-17-2010 01:41 AM
What steps do I need to take to prepare my car for Forced Induction? (junkyard turbo) Xenostalgia Camaro Discussions 27 06-07-2005 10:13 AM
Engine Management: Choices for Forced Induction Setups igor@af Tech Check 0 07-21-2004 01:53 AM
Engine Management: Choices for Forced Induction setups texan by texan (Brian) 8 09-03-2003 09:41 AM
3" exhaust system choices for forced induction use?? JD@af Forced Induction 4 06-03-2002 04:33 PM
