Go Back   Automotive Forums .com Car Chat > Nissan > Frontier | Navara
Old 12-17-2004, 03:49 AM   #1
altonvague
'01 v6 tyranny & cluster problem
I have a '01 SE-v6 Frontier w/~130k miles.
Recently I was moving back out to California from misery (MO), a little overloaded with a trailer.
I was cruising on I-5 in 5th gear with my cruise control on when my truck RPMs started to climb higher & my speed drop slowly.
I put in the clutch the cruise control turned off & I let it back out & tried to accelerate & the same thing happened.
I shifted into 4th & tried to accelerate, this time I had power.
I went back to 5th after reaching 60mph, tried to accelerate a little. I had no prob. Went back onto cruise control & about3 min later the same thing happened.
Since I haven't been towing any thing it has happened twice.
Is this the sign of a clutch or tyranny prob?
Another funny thing happened on my way out to Missouri. Again while cruising at 80 on I-80 at night, not towing anything, my cluster went haywire all of the needles went dead, the LED zeroed out (i.e. 00000000)then went dead killing my cruise control with it, I had thought the truck died.
The cluster lighting & headlights had stayed on the entire time & then the LCD just restarted, the cruise light was blinking, but the needles stayed dead like the truck was off.
Instead of pulling off the freeway I decided to do a rolling restart, turned the key off threw it into neutral put the clutch in & tried to fire her up, well when I turned the key to the run position the needles came back to life & the tack told me that the motor was still running.
About an hour later the same thing happened, I pulled off to try & assess what the problem, fuses, maybe a wire I kicked, anything but I couldn’t find any.
It hasn’t happened since. Any suggestions?
TIA,
Jason
altonvague is offline   Reply With Quote
Old 12-23-2004, 02:21 PM   #2
kuvasz101
Send a message via Yahoo to kuvasz101
That is your clutch slipping. The miles show it's time for a new one. The slippage you described is 100% clutch. Clutch, pressure plate and throw out bearing should be changed as a set. Good Luck
kuvasz101 is offline   Reply With Quote
