Go Back   Automotive Forums .com Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-10-2008, 01:29 PM   #61
Cobra4B
Cobra4B's Avatar
Re: Hello to Panoz GT-RA and Series Car Owners
^ PMed you Jim
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Cobra4B is offline   Reply With Quote
Old 01-10-2008, 05:16 PM   #62
94_panoz_#7
Be warned that the BBS RX233's that BBS sells for Mustangs would have to be bored out to fit over the hubs on these cars. Maybe the ones referenced above included that machining; the guys at BBS should be quite aware of this.
94_panoz_#7 is offline   Reply With Quote
Old 01-10-2008, 06:21 PM   #63
Cobra4B
Cobra4B's Avatar
^ Eh... shit... I'll have to check on that... Going to fit a wheel.
Brian B.
Old 01-10-2008, 08:30 PM   #64
94_panoz_#7
The ones that were bought from the school would definitely have the machining done - I was talking about brand news ones from BBS.
Old 01-10-2008, 10:28 PM   #65
Cobra4B
Cobra4B's Avatar
^ The new wheels and my "old" wheels are 100% the same. The spacer fit's perfectly w/ a sort of "click" in the counter-bore on the back of the wheels.
Who knows maybe BBS has machined them properly for that. When I called the rep confirmed that they're the wheels used on the GTRAs, but brand new.
Brian B.
Old 01-12-2008, 09:41 PM   #66
Blue Streak 21
Blue Streak 21's Avatar
In the long run, 18's are the way to go for me. I've got great connections for 18" rubber, and it seems to be the std size for most racing applications (best combination of I**4 and weight). Yes you can stick huge rotors inside of 18" wheels. I'm looking at e-bay right now...
Jerry
1999 Panoz GT-RA
Blue Streak 21 is offline   Reply With Quote
Old 01-13-2008, 12:20 PM   #67
hooked8
hooked8's Avatar
Thanks for the input gang - I have a technical guy at Yokohama, who knows the guys at BBS working on this...one issue is that with the tire we want to use, they think they want us on 18 X 10's on all four corners - Josh says they've never run the 10" wides on the fronts but guesses its ok...but I think I'll have to pull the trigger sooner than later on the frame reinforcing...we'll have quite a bit better rubber on the road...cars will be faster....I'll keep you posted on what they say about machining, and offset - Josh says offset on the rears is 20mm and the fronts, running 18 X 8.5" was 25mm - this may take some time, but I'll keep ya'll posted on what we find...
hooked8 is offline   Reply With Quote
Old 01-13-2008, 05:53 PM   #68
GaryJonesMotorspor
Jim
If you want a set of the 17 inch wheels I will let you have a set for $200.00 and I think you can work the shipping out....Gary
GaryJonesMotorspor is offline   Reply With Quote
Old 01-13-2008, 06:05 PM   #69
hooked8
hooked8's Avatar
Gary - thanks for the offer - but I'm guy trying to sell the 17's as I'm moving to 18's...thanks again!!! david ray
Old 01-13-2008, 06:22 PM   #70
David Eastman
Jim
Don't you have pleanty of duct tape hanging around.
David Eastman is offline   Reply With Quote
Old 01-13-2008, 06:36 PM   #71
Gatorac
Gatorac's Avatar
Originally Posted by David Eastman
Jim
Lot's of duct tape. You have room for an extra set of wheels for the ride to Roebling in March? Trade ya.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Gatorac is offline   Reply With Quote
Old 01-13-2008, 09:29 PM   #72
GTS#25
GTS#25's Avatar
The GTS cars are running either BBS RGR 18x10 on all 4 corners - or 18x11 on the rears.
Pirelli p Zero 285/645/18 front 305/645/18 rear
I am running 18x10 on all 4 corners. I would go with the larger rears if I were buying a new set.
Some guys are running CCW 3 piece wheels instead of the BBS.
GTS#25 is offline   Reply With Quote
